Installed Johnson CM30 pump
Old Aug 21, 2007 | 01:49 PM
Vadim @ FD's Avatar
S600TT, R350
It is as quiet as stock.
Old Aug 21, 2007 | 04:58 PM
StevesAMG's Avatar
03' E55, 06' Kawasaki ZX-10R
Originally Posted by Shaun
Just bought the last one. One question for the guys that installed it. Is it louder that the stock one?
I didn't even know they made noise lol
Old Aug 21, 2007 | 06:39 PM
tigerlam92's Avatar
E55
Some water pump will make so much noise that it may drive some people crazy, like the one that Vortech put in their kit. I had no problem with the noise since my car was pretty loud already.
Can someone confirm that the pump on Ebay is really a CM30 (as advertise) and not the weaker built CO30 which has the problem of premature leaking. I also bought one, hahaha. I have a brand new CO90 if anyone wants to buy it now.
Old Aug 21, 2007 | 07:33 PM
StevesAMG's Avatar
I bought it, installed it and it is indeed the CM30.
Old Aug 21, 2007 | 08:32 PM
tigerlam92's Avatar
E55
thanks
Old Aug 22, 2007 | 07:58 PM
TopGun32's Avatar
it looks like I missed out on the Ebay purchase.
Any body has another place were we can buy them for around $80?
I e-mailed the Ebay seller to see if he has access to more pumps.
Summer is almost over.. but my car is finally working properly.
New SC clutch (newer design)
New trans
New torque converter
the transmission is still a bit sluggish at times.. but overall its much more precise than before.
Now I just need to keep my ITA temps down with these ASP pullies.
Old Aug 23, 2007 | 11:22 AM
  #32
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
Why does no one mount a seperate fluid resevoir in the car and seperate the two cooling systems? It's got to produce much lower IT's and ET's
I work with some turbo Drag racers and they ALL mount seperate fluid resevoirs in the car to cool the intake air. They fill them with ice and water before each run and intake temps are usually in the 40 degree range even after a 7 second pass at over 200 mph in 95 degree weather. In fact, IT is one of the most critical components of a good run besides traction.
I'm sure I'm not the first to contemplate this mod, so why does no one do it?
Old Aug 23, 2007 | 11:50 AM
  #33
pshek's Avatar
2003 C-Class Sportcoupe
Johnson CM30 and CM90 have magnetically driven impellers. CO30 and C090 do not. Instead, they have a mechanical seal that needs to be replaced often. On the CM pumps you don't have to worry about seal going bad. There's instructions on how to replace the seal on on the CO90 pumps on their website.
Old Aug 23, 2007 | 02:19 PM
  #34
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
what...you mean like this? btw, i'm not the only one who's done this with their 55.
unfortunately, we'll NEVER be able to cool iat's as efficientley as custom air-to-air i/c's do but we should at least be able to get much closer to ambient.
Old Aug 23, 2007 | 06:34 PM
  #35
Jrocket's Avatar
E55
Space! Not enough of it under the hood.Some have done it but mounted the unit in the trunk,now you have alot of hose for that cold water to travel through.
Old Aug 24, 2007 | 11:41 AM
  #36
NOW THAT'S WHAT I'M TALKING ABOUT! Very nice looking installation. How much of a performance gain did you see over the stock system. I'm betting it was signifigant?
Old Aug 24, 2007 | 01:10 PM
  #37
chiromikey's Avatar
i've only had it finished for a few weeks so i haven't had a chance to hit the track yet but i'll make sure to post the results of that and my datalogging when i do.
iirc, rflow has shown a significant decrease in iat's from his.
Old Aug 24, 2007 | 08:34 PM
  #38
Jrocket's Avatar
E55
I was told there is 2 different models of the Cm30? 3/4 and 5/8's,is this correct?
Chiromikey...what ones did you get from Bill?
Old Aug 24, 2007 | 10:08 PM
  #39
chiromikey's Avatar
3/4".
not that there's much difference but the oem is 5/8". i've not seen a 5/8" offered for the cm30 (but that doesn't mean much ).
Old Aug 25, 2007 | 12:35 PM
  #40
tigerlam92's Avatar
E55
From my experience and what I have seen, the water to air IC is more efficient on the track than the air to air just because you can dump ice in after everyone run.
However, you are right for the daily use off the track then the air to air will be more efficient than water to air because it will not be practical to use ice for the water to air application.
Old Aug 26, 2007 | 05:24 AM
  #41
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
and what would an air to air IC be?
