Hub centric rings
Old Aug 18, 2007 | 12:25 PM
e55 baller's Avatar
W221 S65 AMG
Hub centric rings
I need to get some hib centric rings for my Iforge Daytona's. I don't know how I have been living with the vibration for 1+ years now but I could not correct it with balancing or an alignment.
Does anyone know what the measurements are for the ID and OD for hub centric rings for the E55?
Old Aug 18, 2007 | 12:34 PM
JAYCL600's Avatar
new balance
Isaac,
the OD will be what the diameter of the wheels are, the ID is 66.5mm
Old Aug 18, 2007 | 12:37 PM
e55 baller's Avatar
W221 S65 AMG
cool thanks! Btw, what is the bolt pattern for the stock wheels 5x112 or 5x114.3
Old Aug 18, 2007 | 01:07 PM
Ted Baldwin's Avatar
300ce
..........5x112. I think all MB sedans are 5x112.
........this hubcentricity stuff with aftermarket wheels can be a PTA. The hub rings have to take into account the inner diameter of the after market wheel you are using. As I understand it, the problem is not solved by ordering hub rings with the OD and ID of your car only. Ideally, the vendor you purchased the wheels from should have provided the appropriate hub rings for your car and the wheel.
.........I was able to solve this problem in the past by ordering the appropriate hub rings from my local Discount Tire store after giving them the make and model of the car and wheel.
Ted
Old Aug 18, 2007 | 01:23 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
am i out of line thinking that if you spend the kind of money on wheels that iforged rims cost, that they should be hubcentric to begin with??? even my cheapo $1k set of rims are hubcentric for crying out loud!!!
Old Aug 18, 2007 | 04:24 PM
e55 baller's Avatar
W221 S65 AMG
Ted
Yeah I literally can't believe Wheel Botique (dropped 5-6k) on Iforge Daytona's would let me buy the wheels w/o the hub centric rings. The steering wheel shakes badly at 50mph+
I asked them to look into what size rings I need. Otherwise it sounds like I will need to get measurements done by a local shop. Should the front and rears have the same measurement?
Old Aug 19, 2007 | 03:19 PM
sdsilverm3's Avatar
Tell BBS that.
Old Aug 19, 2007 | 03:38 PM
narf's Avatar
W211 E55 AMG
what are hub centric rings?
Old Aug 19, 2007 | 07:46 PM
e55 baller's Avatar
W221 S65 AMG
http://www.prestigewheel.com/Catalog/HubRings66_67.pdf
and check out the google ad after my first initial post. I have had steerling wheel vibrations for years and now know why.
Old Aug 21, 2007 | 11:39 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
e55 baller, Did you buy used wheels or some wheels built for some other car? If they are 5x114.3 and not hub centric they are not for your car. There is no way that a custom built rim for your E55 from IForged needs hub rings to be centered?
IForged would have built them made to order in 5x112 and 66.56 hubs.
Old Aug 21, 2007 | 12:50 PM
BenzoManNY's Avatar
E63, SL 550 Sport,C63 Coupe On the Way!!
You should not need a hub ring on any custom built wheel. It appears you bought wheels for another application WB had listed on Ebay. I purchased 3 sets from them and my friends in Lauderdale use them all the time and never had an issue.
Old Aug 21, 2007 | 01:14 PM
sang55's Avatar
K3 05 E55 sold, 09 GL550
Hey E55 Baller, I had same issue as your when I order my 19'' Iforged Daytona , still had vibration on the sterling wheel . I talked to Steve at Iforged he sent me the new set of Hubring but they still so also I had Discount tire check roadforce and ballance few time but it wont go away . If you found the better set of hubring please let me know or post on forum so everyone who had aftermarket rim can fix their issue.Thanks .
Sang
Old Aug 21, 2007 | 01:40 PM
E55 KEV's Avatar
Veteran: Air Force
Sang
That's very strange. You custom ordered a set of IForged rims and they needed hub rings?
Is Iforged not about to make MBZ hubs sizes?
Old Aug 21, 2007 | 06:42 PM
Ghostrider's Avatar
01 CLK 430
Hey Baller,
Saw your posts and have run into the same problem as you on my Daytona's.... Come to find out that they will make the wheels hubcentric IF you order it that way!! But it's up to the distributor to tell you that.
They send you these crappy plastic hub rings that don't quite fit right with your set of very expensive wheels. I got some nice ones from www.1010tires.com go to the Accessories section.
Hope this helps... -Ghost
Old Aug 22, 2007 | 12:55 PM
sang55's Avatar
called the Prestige Wheel Accessories to ask for Hubrings for my 19 Daytona Iforged but they need the center bore of the iforged wheel , anyone know please help .Thanks a lot
Old Aug 22, 2007 | 01:44 PM
psuball1's Avatar
04 E55, 12 GL 450(wife)
Call i-forged and ask for steve. He should have the hubrings in stock ready to ship.
Old Aug 22, 2007 | 02:48 PM
sang55's Avatar
I got 2 set hubrings of the Iforged wheel but these hubring had a little loose when I tried on the without the wheel . Also talked to Steve yesterday about this issue he said never had any problem , again call Iforged this morning and leaved message but have no replied yet
Old Aug 22, 2007 | 05:30 PM
psuball1's Avatar
The rings should fit pretty snug. I would keep calling Steve until you get a hold of him. They have rings to fit the E55. Unfortunely I-forged only makes hub-centric rims for Porsche, BMW and I believe Corvettes and Vipers.
Old Aug 22, 2007 | 10:05 PM
Ghostrider's Avatar
01 CLK 430
It's stamped on the face of the hub rings they sent....
The O.D. should be 72.62mm.
Old Aug 23, 2007 | 12:02 PM
E55 KEV's Avatar
Veteran: Air Force
Poor business decision by I-Forge.
Old Aug 23, 2007 | 04:04 PM
NGS_E55's Avatar
2013 CLS63 2004 S55
Anywhere to get a hubcentric+spacer?
Old Aug 23, 2007 | 05:36 PM
Ghostrider's Avatar
01 CLK 430
They actually do...
Old Aug 23, 2007 | 05:54 PM
sang55's Avatar
Ok guys , I just placed order a set of hubrings at Prestige wheel accessories . when I told the lady at PWA about Iforged 's Hubring and I also tell her the center bore # of the iforged wheels had a bit loose when I fit the plastic ring on the car without the wheel , She finally tell me there is a set hubrings they have which is match to the hubring I'm looking for because they 're smaller maybe 1/2mm or 1mm compare to iforged hubrings . So I purchased that set and will receive them on monday . I will let all you know when I find out .
Old Aug 23, 2007 | 08:13 PM
sdsilverm3's Avatar
So I guess the same thing could be said of BBS?
I think not.
Old Aug 27, 2007 | 06:10 PM
E55 KEV's Avatar
Veteran: Air Force
I think not.
BBS does not make custom ordered rims. I expect off the shelf rims to need hub centric rings. I don't expect it from a custom wheel maker. Again, poor business decision by Iforged.
