Would be nice if the new E63 had the difusser somthn like this!
E-550 Coupe 2010 SE
i see...its really cool... butttttttttttttttttttttttttttt
http://www.vorsteiner.com/benz/models/pdf/e55.pdf
$1,100 for that little plastic defuser... thats stuped.....
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
E-550 Coupe 2010 SE
to be honest with you, i think its really cool, i would get it, but for a maximum of $200 bucks! These guys are NUTS
there must be a replica somewhere..lol
It's a diffuser
http://en.wikipedia.org/wiki/Diffuser_(automotive)
![](http://www.supercars.net/carpics/3250/2006_Acura_RSXASpecConcept2.jpg)
If you're going to make a custom one, why not have it include the exhaust + piping as well?
A diffuser, in an automotive context, is usually a shaped section of the car underbody which improves the car's aerodynamic properties by enhancing the transition between the high-velocity airflow underneath the car and the much slower freestream airflow of the ambient atmosphere. It works by providing a space for the underbody airflow to decelerate and expand so that the boundary between the car's airflow and "external" airflow is less turbulent, and it also provides a degree of "wake infill" (the wake being a turbulent area of low pressure that is caused by the passage of the vehicle through the air; this can cause pressure drag).
As the air enters towards the front of the car it accelerates and reduces pressure. There is a second suction peak at the transition of the flat bottom and diffuser. The diffuser then eases this "high velocity" air back to normal velocity and also helps fill in the area behind the race car making the whole underbody a more efficient downforce producing device by reducing drag on the car and increasing downforce.
The aft part of a car underbody can be a diffuser. It tries to connect the underbody to the back without producing turbulences so that Bernoulli's principle applies and the pressure increases while the velocity decreases. The side and the roof end in a sharp edge, so that their pressure does not increase. Because the pressure in the back tends to equilibrate, the pressure below the car is lower than on the side and the roof of the car.
Note that the front of the car slows down the air without a diffuser making this the ideal place for an inlet. But a diffuser reduces the pressure in front of the car and thereby the amount of air pressed below the car. Sometimes a diffuser is used to let the wheel-casing also pump down the pressure below the car. Many small engine-exhausts in the back also help pumping. The exhaust from the engine compartment in the underbody can blows the air outwards by means of convergent nozzles, which reduce the pressure from the high pressure in the compartment to the low pressure below the car (the nozzle is the inverse of the diffuser).
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
E-550 Coupe 2010 SE
