mb isn't the only ones detuning ecu's!
poor bmw guys are going through the same thing!
http://www.m5board.com/vbulletin/sho...d.php?t=103117
Thing is I have asked and some people say the tune is good, some say it’s bad.
The secondary air pump recall is what you are referring to yes?
Techs have told me that this flash reduces load limit, but the car still produces same power in dyno mode.....
From my understanding it's the older models that got hit the hardest.
Maybe new ones are not complaining because the never had the old tune to begin with. Or it just works better on newer ones?
Can you answer me this?
Has any car got a dyno of it before and after the flash while still remaining stock?
Trend effect by year produced?
thanks
thanks
thanks
thanks
I think the better times were not the result of the flash. I just learned to launch better.
..........this is one of tose topics that is is getting a bit redundant. Yes, there have been before and after dynos which show that the ECu pulls timming and dumps fuel as the engine is taked.
............I have even published a print out of from DAs that read "ENGINE LOAD LIMIT IS ACTIVE" on my car. What other evidence does one need? When atomic bombs were dropped on hiroshima and nagagaski, not everyone died. Does it then mean that no aomic bombs were dropped? If one's car is unaffected by the flash, does this mean that those that were adversely affected are just making it up?
......If after all that has been published on this forum another person takes their car to dealer for flashing, an argument can be made that they deserve their fate.
Ted
Ted
Ted
Ted
Ted - not at all trying to say that it never happened. I am sure it had an effect on many 55's. Just not mine.
And based on info from this forum, my SA is under strict instructions to never reflash my ECU unless I tell him to.
Ted
Ted
but knowing is better then not knowing. I have asked techs & sponsers and have been replied back with ' no it does not effect performence' but then i read a few posts and people say it effects!
sorry if i upset you ted, could you please give the link to this DA you are talking about, Yes there is info on this forum but there are no FAQs that i know of to help find things like this.
cheers
2003 E55 & 2014 GL550
The MB E55 flash is a no-brainer considering the stats that we are getting out of the 63's, but why would they knock down the power on the M's.
Any ideas??
Any ideas??
Well this is why i would like to make sure, not that it wil make any difference with me as i am an 06 and most likly have this on my car already
cheers
cheers
https://mbworld.org/forums/showthrea...d+limit&page=2
Ted
