I need new tires. How wide can I go on my 18's
285/35/18
The OEM setup has a larger diameter in the front, but that is just because they are a little stuck between sizes for the 245s.
You will be fine. Same rear, 0.5 inch wider in the front.
When you mount mount a wider tire on a rim narrower than what is specified by the tire manufacturer for the tire, you are pinching in the sidewalls and causing the sidewalls to be loaded in a manner they weren't designed for. It may not happen immediately, but the adverse loads on the sidewalls can cause them to fail. It's a safety issue, pure and simple.
Yes, I've heard lots of guys say "well I mounted such and such on this width rim and never had a problem", but that's not the point. Yes, the tire may fit, but your way more likely to experience a catastrophic tire failure doing a canyon run when you've got a tire mounted on a rim it wasn't designed for. I've seen guys blow out on tires on the track during BMWCCA driving events where the sidewall failed because too much tire had been mounted on a narrow rim.
Here's the deal:
255's require a rim width range of 8.5" - 10"
285's require a rim width range of 9.5" - 11"
AMG wheels as found on our cars are available in 8.5" and 9.5" by 18" sizes if you want to run larger tires. I personally have 9's in the front and 9.5's in the rear, and there's no fitment issues.
Any wheel width usage narrower for those width tires as shown above and you're automatically nominated for your own personal Darwin award when something goes wrong. Let's be safe out there.
I currently have a used set of Mich Sport 275/40/18 in the rear. It looks a bit chuncky.. but no rubbing issues at all. Also the ride is very comfortable even as sports 2 suspension.
275/35/18 is ideal I think for a 9" rim x 18.
if you upgrade to 9.5 and depending on the off set it will vary
Anyone try this yet?
I know the CLS55 AMG 19"s won't fit with the EOM 285 tires.. they are also 9.5 wide.
you might need to downgrade to 275's..
but I'm 100% sure.
