Is it a fact that ...
Old Sep 14, 2007 | 02:46 PM
DFW01E55's Avatar
'14 ML BT
The rotors must be replaced when you do pads?
Or is it a revenue generating requirement only?
Old Sep 14, 2007 | 02:53 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
If the rotors are below spec, they won't cut them at the dealership.
$1800 later, I have new brakes.
Rouven036's Avatar
Cars with Stars
when they are too thin-yes.
SteveFox's Avatar
Bentley Flying Spur, CL550
To my knowledge a revenue generating requirement.
Old Sep 14, 2007 | 03:04 PM
DFW01E55's Avatar
'14 ML BT
Thanks guys.
I was just interested as to how MB might be different from every other rotor on the street. They're not. (Unless it's the 65 rotors.)
Revenue generator ... I can understand that though.
Old Sep 14, 2007 | 03:43 PM
SSM AMG's Avatar
2004 S55 AMG
God I hope its not a Revenue generator. Just got told by the dealer that I need new front pads and rotors. Bought them for $800 online. Isn't the rule new rotors for every 2 brake pad changes.
Old Sep 14, 2007 | 03:59 PM
WayneE's Avatar
'72 Suburban
Shaun, the rule is measure the thickness of the rotor and check min thickness spec.
Does MB stamp the min thickness on the rotor hat, like some manufacturers?
Old Sep 14, 2007 | 04:03 PM
DFW01E55's Avatar
'14 ML BT
Originally Posted by Shaun
... Isn't the rule new rotors for every 2 brake pad changes.
That was the rule of thumb (back in the day) and it figured you cut the rotors once.
In the end the answer is thickness as Wayne points out.
Old Sep 14, 2007 | 04:25 PM
Rguy271's Avatar
2004 E55
My BMW dealer told me they wouldnt allow me to do anything but replace both the rotors at the same time, even if the thickness was acceptable for fear of a lawsuit from me. i went to an indy and had new pads added.
Old Sep 14, 2007 | 04:50 PM
jangy's Avatar
2015 S212
Pad and rotor combos can wear at completely different rates. Rule of thumb is 2 sets of pads to a rotor, but the decider is always the condition of the rotor. Cracks, etc. and minimal integrity.
