What rear tire presure is best for drag racing? I have PS2's.
Hard to test because car will shred the tire at any air presure.
I know the real answer is Quaife LSD and BFG Drag Radials. Proven package for lower et's.
BRAND NEW in 245 front and 275 rear 18's brand brand new tires, you should have amazing grip?
If your tires have 10k miles on it and u drive it hard u might need a new set.
the mbz 55k engines burn up the tires in these cars cause of all the tq.
IF you never really get ur tires to squeel but if u go wot with traction it does the same thing, the tire gets used up alot due to the high amount of tq in this monster.
Let me know if you have any questions, I'll be here to help.
Sincerely,
Aaron
Stay out of the water box when you roll up as water will accumulate in the tread and run down to the contact patch when you line up. Just a bit is enough to lite them.
Lastly, burn those PS2's up as they need lots of temp to stick, not so much as to ball up the rubber.
Good luck.
I was able to cut 1.80 60' with 36 PSI in the rear, but seem to hook better around 30-32.
I heat them just enough to pull a bit of rubber up off of the track.
