seperating the coolin lines question?
06 EuroElites E55
if i have the I/c and engine run on their own will the ECU still be able to tell the I/c to turn on? or do you still have your pump running at all times? will my over heating warning systems still work?
i belive this is a grat way to keep our cars cooler but how hard is it to do? and will it all still function correctly?
E55
ECU will still turn on the IC pump,UNLESS you wire it seperatley to run on when the key is on.I like to have the pump run whenever the key is on.All cheack lights will still work either way you do the pump.
2005 E55
E55
To do it correctly you need to get a bosch 30a. relay and wire it into the stock fuse box area.Im not good at explaining,just hands on doing it.
06 EuroElites E55
is your system seperated? if so how much do you think it helped?
E55
I cant honestly say how much it helped,but when you add up all the little things it does keep the IAT's down more and brings them back to normal range faster after hard runs.Wired to run with key on,bigger HE and pump,and seperate system is what I think is the right way to go.
06 EuroElites E55
E55
After you get those temps logged,then seperate the system,add a resivour(place to add water also) for the IC circuit side and log the temps from both previous locations again.Compare the 2 and see what you get.
I found a switched source that acts as the trigger for this relay which is hidden down in the corner of the fuse box. I tapped into it and ran that trigger wire along with the larger blue wire in back for constant +12v to the pump relay.
I fished the wires behind the engine compartment and pushed the relay down next to the battery under the fresh air intake. From there I ran a ground wire to a grounding point next the SBC and from there to the pump. The other wire goes to the red lead on the pump. So far it's worked flawlessly and activates when ignition is in ACC position. I'll complete the project when my new heat exchanger arrives.
Good luck and make sure you use hose pinch pliers if you separate the lines. Helps keep things much cleaner.
