Ron Davis Heat Exchanger
It looks like there's a few options out there now for anyone wanting to replace the stock HE with a larger one or add a secondary HE like I'm doing. Glad to see the market bringing down the cost of these things.
Here are some pics. I'll do another DIY when I do the final install, as well as, IAT temp logging before and after.
Yes, I've got my stock pump still installed and running full time. I replaced it several months ago with the newest version, but will install my CM30 when I do the HE. I didn't want to drain the system twice.
In my experience, I would greatly disagree with the above statement. The unit pictured is nice looking for sure, but I actually don't think its much better than the stock unit, if at all. Will it work? Yes, but only because it is being added as a secondary. Is it more efficient than the stock unit? Somewhat. Sure you are adding more cooling capacity, albeit a small amount, but at the expense of adding another unit to block airflow. This is on top of the fact that the design of the unit is not great to begin with.
We are looking at a single pass, tube and fun unit, that has square end tanks. If anything, this unit should have had angled end tanks, being that its a single pass design. Fluid will not flow evenly to all the fins. In fact, you will have pooling of fluid in the corners of the end tanks because of this.
The tube and fin core itself is cheap, but it is light. This is why it is used in many OEM applications. It is not as efficient as bar and plate, especially in a heat exchanger type of application. Tube and fin passages are 1/16" thick, and they are open passages. Bar and plate passages are 1/4" thick, and are internally finned, which helps distribute the fluid evenly in the passage, as well as maintain a good flow rate through the larger passage. Bar and plate cores act more as a heatsink, which is what we want in this type of application. Bar and plate cores also tend to see less damage in a front mount application.
The unit pictured will work for BrianS, mostly because it is part of a custom separation setup. I just don't see this as being an ideal until for the E55 in general. If used by itself, absolutely not. Used as a secondary, helpful. But why put two adequate units together to make a decent setup? Get rid of the mildly efficient stock unit all together, and go with a unit that makes sense. There is a reason most aftermarket ICs and HEs use bar and plate cores. This is across all markets, not just automotive.
Edited: I just wanted to add that Ron Davis makes some beautiful pieces. I am in no way bashing their work as a whole. I just don't think this specific application was thought out very well.
FYI: I have a large dual pass bar and plate on my car in front of the stock he, but we have tried different style he's and like I mentioned before quickly realized that overall water volume had more of an impact on iats than the he type. This has been my experience with the 55.
Size does matter, but if the coolant is just flowing right thru the HE, it won't be as effective.
if your bar and plate h/e can consistently keep iat's even remotely close to ambient during summer months i'll scrap my extensive custom i/c system and buy your whole package.
code3, if your unit was available at the time then I definitely would have considered it since it looks great and plug-n-play is a bonus.
So what is the problem with the IC core you keep referring to? I know the C32 unit certainly isn't that bad. Sure it could use some smoothing out, but overall the unit is perfectly fine. Has the core been isolated by itself and tested to show that there is a problem that exists? Or is it an assumption based on exhaustive testing of every other component int he system?
I have spent an extensive amount of time around my Cobra and C32. They use near identical setups as the E55. I can say without a doubt that the weak link is the stock HE, and total system fluid capacity. I was making over 500rwhp in the Cobra. Never had an issue with high IATs at the track or otherwise.
No offense, but have you spent any time around air to water based systems other then the E55? I'm not saying the IC cant be improved, but it certainly isn't holding anyone back from achieving great results.
Maybe your expectations are too high? Ambient IATs during summer months? How about 20°-30° over ambient over 100°? There is hardly a difference in what we are trying to achieve in the bigger picture. Thats what I consistently see during aggressive driving. The SC doesn't shut off, the car is always making power and never feels sluggish. Under 100°, the gap closes, and gets closer to ambient very quickly.
I converted my C32 to a gravity based system. Fluid comes out of the IC hot, down into the HE to cool twice, through the pump, back up into my larger aluminum reservoir, that is baffled to cool more, then into the IC again. If I dump ice in to my reservoir, that ice cold water goes directly into the IC. Obviously the ice is only real beneficial for drag racing.
We are all on the same page as far as what we all want. Consistent power. I truly am interested in getting the problem solved. After spending time with the E55, I don't see what is so different about it. Separate the fluid, increase capacity, upgrade the pump, and upgrade the HE. I am interested in seeing what testing has been done to prove that the stock IC is the problem.
Edited: I just wanted to say sorry BrianS, I didn't mean to muck up your thread. Just trying to promote some good discussion
Yes plug and play is a very nice option
