Quick question regarding Evo cooling kit
Old Nov 11, 2007 | 02:45 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
Question Quick question regarding Evo cooling kit
Yoyo,
Just a little confused regarding installation of the evo cooling kit.
When you install it, do you remove oem pump and replace it with the pump that comes with the evo cooling kit, or is the pump an additional pump?
I ask because I have the updated mb pump and if I have to replace it, is the evo pump better
Old Nov 11, 2007 | 03:20 PM
E55 RUSS's Avatar
E55K
Originally Posted by Zod
Yoyo,
Yes...you replce yours with Jonhson pump...
Old Nov 11, 2007 | 03:34 PM
Zod's Avatar
Zod
hmm but is it better then revised stock one?
also it does not look like cm30 it seems much smaller
Old Nov 11, 2007 | 03:38 PM
Sunny55's Avatar
2005 SL55 AMG
The CM30 looks smaller than stock. The CM90 is bigger than stock. You got the CM30 Johnson pump.
Old Nov 12, 2007 | 01:24 AM
Zod's Avatar
Zod
ok so i am told you do remove the oem pump and replace it with the pump that comes with the cooling kit.
Is this pump better then revised new oem pump?
evo included cooling pump is not cm 30.
i do not want to be replacing a better pump with a lesser if you know what i mean. If it is an upgrade then all is good
not many people seem to have the improved oem pump or very little has been mentioned about it
revised oem pump > evo included cooling pump
or
evo included cooling pump > revised oem pump
any one?
*edit going to try and get a pic of the pump*
Old Nov 12, 2007 | 01:57 AM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
don't be afraid of the smaller size of the cm30. any johnson pump is better than an oem unit...including the upgraded version.
Old Nov 12, 2007 | 03:33 AM
E55 RUSS's Avatar
E55K
I have both pumps working my IC system...
Old Nov 12, 2007 | 03:35 AM
Zod's Avatar
Zod
how the pictures in the user manual show i need to remove my pump and install the evo provided one. At work so the kit is not with me
Old Nov 12, 2007 | 05:08 AM
E55 RUSS's Avatar
E55K
You can use both or just one...My installer installed 2...seems to work OK...
Old Nov 12, 2007 | 11:53 AM
chiromikey's Avatar
do not use both pumps. iirc, russ has two of the same pumps running an elaborate i/c cooling system and is not using the oem pump with a johnson pump on a stock system.
Old Nov 12, 2007 | 12:04 PM
jangy's Avatar
2015 S212
or
any one?
I dunno, either but I have the new one and have had not heat issues.
Old Jul 29, 2008 | 06:15 AM
khaz3al's Avatar
2005 vw touareg, sl500 r129 SOLD, 2002 sl500 kleemann
its cuz u dont live in kuwait .... we r talking of up tp 50ºC!!
and with the supercharger its even worse lol.
