Dragstrip times
I've only been to the strip in the 55 once before and my best time then was 12.45, completely stock, and the weather was a bit warmer. Tonight I did a 12.26. This run also had my best 60' of 1.90 and the trap was 114.73. I turned three 12.3s tonight each with 2.0 60' times. My best trap was my first run at 115.72 which was one of the 12.3s. These times were on well worn stock Conti's in 40 degree weather. Our track is now closed until the middle of February so I won't get to try my other mods (soon to be installed) until then. I had a great time and the E55 got lots of attention. I was told there were a lot of people upset about my times.
http://www.memphismotorsports.com/
nice run how did u get it off the line?
I probably could have done better without the Sprintbooster. The track was prepped well and traction was pretty good. The Sprintbooster makes the power harder to control as it comes on very early when you start to mash the pedal. If I could have got a 1.8 sec. 60' time I would have been close to turning in the 11s.
Thanks for thats, last question, what you mean by the sprintbooster?
And once again great time!!
Best time to date is a 12.16 with a 1.799 60" time. Math is simple, whatever i add to the 60' time goes right to the 1/4 run...
TK
There is something much more important than anything you can do to your tires.
All sub 12 second passes in the STOCK 55's have great 60ft times but also are run 99% of the time at a NEGATIVE DA.
Also as you and jrocket pointed out to me it seems the DA may actually be more critical to the 55k. You can certainly see a huge disparity in 55 times run at 48-60 and 60 and above.
What tire pressure do you run on your DR's Juicee ?
I have just been doing the 28 lbs. My best 60ft was 18 psi but the low psi seems to kill trap speed. so I compromised at 28 , LOL.
waxking apologies for the hijack, rflow and I love discussing this DA stuff.
I am so excited for 11/30 and especially 12/8 in Sacramento. wish you guys were all able to come out!!
