another Pulley ... Final?
Old Dec 2, 2007 | 02:27 PM
dyno's Avatar
cls 55 or FIAT Coupe T20v-6speed
indeed in OEM pulley (and those oem-modified like ASP ..) both metals of the first outer ring for acc belt and the second ring for SC belt are separated from the other metallic structural element that is bolted to the crank, by means of an elastomeric material.
it is that 2mm thick rubber ring that crosses the pulley from top to bottom
RennTech vs OEM
Kleemann vs OEM
This elastomeric material has a dampening function and, mostly important, insulates at best our delicate crank from possible disturbing forces arising from other devices like accessories and Supercharger.
it comes that outer rings shouldn't be bolted directly to that structural element.
well, it makes sense .. a lot
according to this finding, Asp ended up by simply screwing and welding a larger outer ring , without substantially touching any structural parts of the pulley. only hitch is that it's not so fine-looking and the outer ring is not swappable.
Others, like Renntech, Kleemann, Evotech went for the substitution of the outer ring.
In more recent models , like VRP and a model presented by LET) the outer ring appears screwed to the strucutral element.
.. and Let
.. here, too, no rubber between outer ring and back structure
Evosport: don't know .. don't have enough clear images.
The attached image shows another interesting method
...rough indeed .. but some of you could do better
It reaches both goals:
- keeping original concept
- possibility of swapping the outer ring
this appears to me the Final Pulley
Old Dec 2, 2007 | 03:06 PM
Jrocket's Avatar
E55
Where are you going with this thread?
Old Dec 2, 2007 | 03:26 PM
SRT6's Avatar
srt 6 chrysler crossfire
+1 I don't get it lol
Old Dec 2, 2007 | 03:34 PM
RoydRage's Avatar
SL55
Touch Up.
It looks kinda Ruff...
If you did this yourself you should be applauded very good, I meant no offense, I'm just looking at it like it should be as a finished product. Hear it is with exposure, and sharpening corrected.
I'm going with the EvoTech, proven, reliable, and done well. I'm not messing around with designs that are not tried and true.
Best,
RoydRage
Old Dec 2, 2007 | 03:44 PM
dyno's Avatar
looking for .... Royalties
Old Dec 2, 2007 | 03:50 PM
dyno's Avatar
.. not suitable for yours
Old Dec 2, 2007 | 04:07 PM
derrick_lui's Avatar
My ex-cars: 03 E55,04 C32, 05 C55 ,03 E320
No sweat..Good info dude!
Old Dec 2, 2007 | 04:14 PM
dyno's Avatar
don't catch your jargon .. but here' one more info: installed
Old Dec 2, 2007 | 04:29 PM
dyno's Avatar
Best,
RoydRage
yes, ..fine
but seems to me they added a bit too much rubber ... could be too loose and start up dancing
Old Dec 2, 2007 | 04:49 PM
RoydRage's Avatar
SL55
So!
You have done this... Excellent!
How many mm did you go for? And have you balanced the assembly?
Best,
RoydRage
Old Dec 2, 2007 | 05:01 PM
dyno's Avatar
it's small ... so no further balancing
but, as said above, I posted here for those willing to make all proofs needed for larger rings
should anybody come out, .. hope will remember me
Old Dec 2, 2007 | 05:25 PM
rflow306's Avatar
2005 E 55
You did not re-balance, why would you neglect something so simple? Anything that spins faster than 1800 rpms should be balanced imho.
I do agree with using the factory style HB as our engines don't spin faster than 7000 rpm to make a difference.
Old Dec 2, 2007 | 05:31 PM
dyno's Avatar
said it had been balanced, but I don't believe it was made properly .. only visually ..
btw, what is a good instrument for balancing a pulley ?
Old Dec 2, 2007 | 05:38 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
All due respect Dyno, but your statement,
"This elastomeric material has a dampening function and, mostly important, insulates at best our delicate crank from possible disturbing forces arising from other devices like accessories and Supercharger."
May not be the case, the disturbing forces are the combustion cycle not the accessories / supercharger. Believe me the belts have far more give and slip than the elastomer on a dampener. It is not only OK to direct drive accessories and supercharger but may be preferred as the elastomer would not have to cope with an additional rotational load of the accessories / supercharger.
Here is a excerpt from, http://www.partstrain.com/ShopByDepa...monic_Balancer
Harmonic balancers are designed to prolong the engine life by reducing wear on the main bearings and main journals and preventing crankshaft failure. The harmonic balancer or the vibration damper is a piece of equipment connected to the crankshaft which job is to lessen the harmonic vibration. Each time a cylinder fires, the connecting rod pounds the crankshaft journal as the force turns the crankshaft, causing energy to be dispersed through the engine. The front of the crankshaft takes the brunt of this power, so it often moves before the back of the crankshaft. This results to a twisting motion and after that, when the power is removed from the front, the halfway twisted shaft unwinds and snaps back in the opposite direction. Even if this “unwinding process” is somewhat diminutive, it causes harmonic vibration.
Old Dec 2, 2007 | 05:52 PM
dyno's Avatar
hi, you are certainly more correct than me as I'm not an engineer
I don't know what they studied at AMG ... therefore I simply think that the less we change, the less ne need to study as they did ..
Finally, I'm only looking for a simple and fast method, while reliable, for changing desired SC gear
Old Dec 3, 2007 | 01:47 AM
SRT6's Avatar
I am sorry I didnt get it because of the way you worded it. Thats pretty nice I hope all is well, I would hate to see you have to replace the crankshaft or even worse that thing shredding the inside of your engine compartment.
Old Dec 3, 2007 | 03:56 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Harmonic balancer is primarily to save the crank bearings... AMG app were most concerned about the bearings longevity in this application and I think intentionally made the S/C belt so that it has some slippage. Thats also why I have not gone for the belt wrap kit.
Going for a solid pulley WILL see premature bearing failure / or roasted crank journals... sadly you wont notice the problem for some time until its too late.
Old Dec 3, 2007 | 05:48 AM
dyno's Avatar
hi,
I'm conscious this method needs further studying ..
btw, yesterday evening (because now it's morning here) I went out for a small drive (without any additional ring in my pulley) ... and I was surprised the way my engine was rocketing
... maybe the combination of cold air and fog?
Old Dec 3, 2007 | 05:55 AM
dyno's Avatar
ciao Steve!
don't know if there exist direct application without belt
certainly result would be better but I think not for long
... maybe applying the same technology used by BMW on bike's transmission
Old Dec 3, 2007 | 08:54 AM
stevebez's Avatar
When I talk about solid pulley I mean undamped as opposed to gear driven from crank ...Ouch dont even want to think how long gears / internals will last in that type of application...
Old Dec 3, 2007 | 10:59 AM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
Both the VRP and the LET pulleys are dampened.
Better-than-stock elastomer or gel dampening, IIRC.
Old Dec 3, 2007 | 02:36 PM
dyno's Avatar
.. does any SC gear driven from crank exist?
Old Dec 3, 2007 | 02:43 PM
dyno's Avatar
I disn't say they are not .. besides, I like them
only, I lack tech knowledge for investigating the consequences of styling
is there anybody able and willing to explain it in a symple way
.. or must go to Wiky
Old Dec 3, 2007 | 05:29 PM
vrus's Avatar
2003 E55 AMG
VERY COOL!! You made your own pulley??
You really do need to make sure that pulley is 100% balanced. Do not install it without re-balancing it.
Old Dec 3, 2007 | 05:53 PM
dyno's Avatar
thanks ..
I'm still thinking at your new ROSSO outer ring you should sell that outer ring together with the quasi- stocker 165. just for peace of mind.
btw, if in your pulley the civil black 165mm ring would be swapped with the rosso one ... should it loose its balancing and the whole pulley should be balanced again, and how ?
In other words: to what extent swapping a balanced outer ring affect new overall balancing of a formerly correctly balanced pulley ?
best
