*** VR550 for M113 55 Kompressor ***
Old 02-01-2008, 11:06 AM
  #201
bfnnrgn's Avatar
SL65
Originally Posted by jangy
I have not been able to hit the limiter since the tune and I have seen 175.
Hmmm, 150ish and you could feel it hit a brick wall and neither of our cars were going anywhere any faster.
Old 02-01-2008, 11:20 AM
  #202
jangy's Avatar
2015 S212
Something is off, then. Even befre the tune, my car pulled all the way to 160. ALWAYS.
Are you sure you got the same flash that is on my car? Mine blasts past 150 in full force.
Old 02-01-2008, 11:24 AM
  #203
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Oh yes. I am planning to mod this thing a bit more before I just start commuting in it. The only reason I waited for now is to give Vadim and Powerchip a chance to finally stir up the technical pot. There is still a great deal of unknowns about these cars and its nice to see a tuner step up and be willing to go into that darkness. One thing I would remind any first timers on. Modding a car is not always the easiest thing and things can go wrong at times. The key is how your tuner treats you, your car, and the situation. I was ready to do pulley, TB, headers all at once, but wanted to give Vadim the platform to do his thing. It may take me a bit longer to get the right mods on the car, but in the end it will be a much more refined tune than if I had done it myself.
I Like the Darkness!
By Giving Vadim and Powerchip the Platform to Achieve a More Refine Tune, You're Reaping in the Benefits because You're Not Rushing Perfection. Excellent!
Yeah, I'm Throwing All of My Mods on them at Once, but I Understand the Situation and I have Patience for Vadim and Powerchip to Create My Perfect Tune.
Old 02-01-2008, 11:29 AM
  #204
bfnnrgn's Avatar
SL65
It should have been. Maybe I got the wrong file or it didn't take? Vadim would know I suppose. All I know is once I got into the 150s I wasn't able to go any faster. I know my speedo reads a little slow, at 80 on the digital readout the analog speedo shows 78ish.
Old 02-01-2008, 04:46 PM
  #205
jangy's Avatar
2015 S212
I'd let Vadim look through the data. Not being able to go past the limiter is not a good sign. What RPMs does it wind up to when going WOT through the gears? Mine snaps all the way up to just past 6500, and it is screaming crazy past 3k.
Old 02-01-2008, 07:13 PM
  #206
bfnnrgn's Avatar
SL65
Well I can confirm there is definatly the stock speed limiter on my car. Just got back from the dyno and tried to do a 4th gear pull but kept hitting the speed limiter at a little past 5500rpm. We had to do 3rd gear pulls. It'll run up to 6500 rpm like it always does.
Anyway, to the dyno.
First run was bad, was spinning on the dyno. They had to spray my tires with vht. 432.4 HP/504.5 TQ
Run 2 432.8 HP/516.4 TQ (might have had similar HP to 3 but there's a gap in the graph right where peak HP would be???)
Run 3 441.4 HP/513.5 TQ
2nd run isolated in case anyone cares.
Old 02-01-2008, 07:20 PM
  #207
jangy's Avatar
2015 S212
I'll make a run to mexico tonight and see what I see, just to be sure. But, I am almost positive that I saw some good numbers the last time out.
The 4th gear dyno is pretty telling. I'd follow up to see if that is the intended tune.
Old 02-01-2008, 07:24 PM
  #208
bfnnrgn's Avatar
SL65
Well what I did see of the 4th gear pull had 444.x HP on it before it hit the limiter if I recall correctly. It's definatly there though, I watched it and the operater was asking me if there was a way to turn it off.
Old 02-01-2008, 07:28 PM
  #209
AMGPRSNPRINCESS's Avatar
SL55 AMG
Will these mods work on an 07 SL55? Are all the kompressor motors the same?
Old 02-01-2008, 07:34 PM
  #210
jangy's Avatar
2015 S212
LOL!! I am following you around. Yes, they will work BUT you have an advantage (80mm TB) that the '06 and prior kompressors don't. Yours would like the pulley, I'd think.
Old 02-01-2008, 07:39 PM
  #211
SL55 AMG
LOL LOL!!! I guess I have some things to learn before delving into modding
Old 02-01-2008, 09:22 PM
  #212
rflow306's Avatar
2005 E 55
The gap is because It lost the tach signal, had they changed the x-axis on the bottom to mph that gap would be gone. If you look closely run 2 was going to be a good pull until something killed power-dip in purple line. You should send the ecu back to get re-flashed to make sure everything is okay imo.
Thanks for posting the graph. You can also take a small usb jump drive with you and save the actual run file at the shop. That way you can use the free dynojet-winpep viewer to view your runs and be able to get more detailed information.
Old 02-01-2008, 09:36 PM
  #213
saman6164's Avatar
CLS55, BMW 540, SUPRA
There is definitely something up with this tune. Not only you are hitting the speed limiter but your AFRs are not where they should be. Send the ECU back and make sure you have the right flash. Your AFRs in past 4000rpm should not be dipping below 11.5:1.
Old 02-01-2008, 09:47 PM
  #214
W219CLS55's Avatar
06' E55, 10' Harley Davidson F-250 6.4L TT
Does anyone know the price on the VRP slr intercoolers? and do you have any pictures or links to the VRP SLR intercoolers? I don't feel like looking through the whole forum sorry.
Old 02-02-2008, 01:34 AM
  #215
jangy's Avatar
2015 S212
OT
The SLR style intercoolers are not part of this package or my future planes.
Old 02-02-2008, 01:40 AM
  #216
Havoc's Avatar
Yes, they go for $500,000. Unfortunately they come with a SLR attached to them.
Old 02-02-2008, 08:48 AM
  #217
W219CLS55's Avatar
I love it. Keep it coming baby.
Old 02-02-2008, 10:07 AM
  #218
jangy's Avatar
2015 S212
Just cause you gotta cool attitude, I'll tell. VRP has a setup that they are developing on a gorgeous black on black SL65. There are pics in the 1000hp thread.
Old 02-02-2008, 12:15 PM
  #219
vrus's Avatar
2003 E55 AMG
Robert,
It looks like your car is making good power.. We will look into the top speed limiter.. They may have forgotten to remove it since it is an optional item when ordering regular PC tunes so when they flashed the VRP tune on there it may have been skipped. The A/F seems a bit richer than what Jangy's car was showing but that could be a variance in the equipment used.. Just to be safe, I'll send a copy of the graph to PC and get their opinion on the flash.
We slowed down a bit on that project once we got the quote from the company that was going to make the casts for us.. We are still working on it, but it was on the back-burner for a while so we could get some other priorities taken care of.
Old 02-11-2008, 02:08 AM
  #220
bfnnrgn's Avatar
SL65
Ok guys, the ECU is pulled out and ready to ship back to CA to get a fresh flash w/limiter removed.
Also the other day I found out my belt wasn't on all the way and was hanging off the back of the pulley, got that fixed.
Stock paper filters are on their way out and a set of BMCs are on the way in.
Once I get it all back together with some miles on it I'll have a new dyno done. Hopefully we'll see something good.
Old 02-11-2008, 09:15 AM
  #221
jangy's Avatar
2015 S212
Good luck with it!! Tuning can take some time and you aren't the only one that had the limiter stay. Hopefully, a re-flash will be just what you need.
Old 02-11-2008, 08:28 PM
  #222
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Jangy, Is your TB done?
When do we see some results at the track?
Old 02-12-2008, 10:02 AM
  #223
jangy's Avatar
2015 S212
TB is on. I am going to grab it and put some miles on while the Airbox is being modified. Headers will be test fit next week and we'll see from there.
I'm ready, fready. Even for maybe an 1/8th one? Anyone down?
Old 02-13-2008, 12:36 AM
  #224
vrus's Avatar
2003 E55 AMG
Robert: Let me know how the car feels once you have everything back together.. Looking forward to your feedback.
You'll finally see why I've been raving about this 80mm TB all this time once you drive your car.. You'll notice how much more crisp and snappy the throttle response is and how much better it pulls on the freeway.. Your drive back to SD should be even more fun!!!!
Let me know how you like it!
Old 02-13-2008, 01:01 AM
  #225
I Like Soup's Avatar
2003 E55 AMG
Oh man...I can't wait! :rubbinghandstogether:
Quick Reply: *** VR550 for M113 55 Kompressor ***
