Are You Still Considered Stock If?
Old Dec 30, 2007 | 06:28 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
You do a run with drag radials on?
Old Dec 30, 2007 | 06:31 PM
AKxSpyO's Avatar
2005 Flint Grey E55
If you can run 11s, NAW!!
Old Dec 30, 2007 | 06:38 PM
NickyBlack's Avatar
E63 AMG, E60 M5
I would believe not, but everyone used them though.
Old Dec 30, 2007 | 07:10 PM
MB_Forever's Avatar
E63 P30, CL500 Sport
Would not be 100% stock but close
Old Dec 30, 2007 | 08:18 PM
So basically the car has to be on tires that came on the car from the factory?
So what tires come on the CLK BS from the factory? Maybe I can use those and be considered 100% stock
Old Dec 30, 2007 | 08:41 PM
MB_Forever's Avatar
To be considered 100% stock, you need to run the car with exactly all the original equipment that came on the car. So original rims, tires (conti's), etc.....
But who cares if it's not 100% stock, even 95% stock is still awsome. I say bring your original wheels with stock tires, and your current rims with drag radials
That way, you'll have an idea of how much difference it made, and I garauntee you'll have a lot of fun in the process
Old Dec 30, 2007 | 08:59 PM
enzom's Avatar
2005 E55
If you had no other modifications done on your ride, then you ran your car "stock on drag radials".
I don't run on Conti's, so I always make sure that people know I run bone stock on PS2's. And when I went wider than stock tires in the rear a few months ago (from 265's to 275's), I made sure that I noted that.
Drag radials (and even R Compound tires) can be a huge advantage, so it is tough to consider a run on drag radials to be a pure stock run. I say "can", because I have been able to pull consistent 1.71's and 1.72's on my PS2's, and I am not sure I would have done much better on DR's. But there is no way of knowing without trying.
Old Dec 30, 2007 | 09:42 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Originally Posted by enzom
...I say "can", because I have been able to pull consistent 1.71's and 1.72's on my PS2's, and I am not sure I would have done much better on DR's. But there is no way of knowing without trying.
well i've tried and for me there's no difference between 16" drag radials and 19" toyo street tires.
...damn computers!
Old Dec 30, 2007 | 11:47 PM
Ah the one I've been waiting to hear from....Enzom thanks for the input. I am trying to dip into the 11's so I can join you and Housclass. According to dragtimes I have the 3rd fastest trap for a stock E55 so the engine is making good power. I have to work on my 60' my best 60' is 1.96. In theory if I can match your 60' that would put me some where around 11.9x. Next time out to the track I will try my stock wheels with the stock conti's. At the current time I am running Nitto 555's 275/30/19.
I wonder if running a 35 series tire allows the sidewall to flex more than a 30 thus giving you some extra bite???
Old Dec 30, 2007 | 11:58 PM
blackbenzz's Avatar
haters crazy
No, once you do anything to the car its no longer considered stock. You can say "stock with drag radials"
...damn computers!
Are you serious? My 60's SUCKED with street tires but when I switched to r comps and d/rs it dramatically improved. Do you turn traction control off?
Old Dec 31, 2007 | 12:14 AM
chiromikey's Avatar
i've run with tc on and off and it's all the same when i'm at firebird. i'm hoping to make some runs at speedworld soon as their track prep is supposed to be much better than firebird's. if that's the case i'll expect some mid-low 1.6's with d/r's and then i can come back and corroborate your experience. if i still run 1.70-1.71's i'll know for sure that it's the ecu/tcu limiting power on launch.
Old Dec 31, 2007 | 12:18 AM
blackbenzz's Avatar
haters crazy
What short time do you usually run with street tires? The d/rs and r comps require a BIG burnout to get them nice and sticky and make sure to decrease tire pressure. Jason is an expert on that stuff, my best time is when he set my tire pressure and helped me with the burnout. Let me know how it goes at the track.
Old Dec 31, 2007 | 12:28 AM
iolithblue's Avatar
my car
i'm pretty new and not a drag racer, so be nice to me.
that said Mb cars can come from the factory with a number of different tyre choices ie pirelli, conti etc. which one of these is "stock"? if i replace the factory tyres with another brand not fitted from factory ie no name retreads (i know, i know but follow the example) is it still "stock"? is taking the spare tyre out "stock"? what if i order tyrefit from the factory and it never came with a physical spare tyre? is runnig it with 10L in the tank instead of full "stock"?
may i suggest stock is defined as summer tyres (ie no R compound, even if they are street legal) in your choice of brand, OEM size or equivalent??
thoughts?
Old Dec 31, 2007 | 12:29 AM
chiromikey's Avatar
i run the same short times on both, 1.70-1.74...unless i screw something up. it's such a fine line between traction and smoke as i mash the pedal and if i wasn't worried about breaking more parts (i already ruined a diff by twisting the axle splines in it) i'd run slicks.
Old Dec 31, 2007 | 12:33 AM
chiromikey's Avatar
Originally Posted by iolithblue
...may i suggest stock is defined as summer tyres (ie no R compound, even if they are street legal) in your choice of brand, OEM size or equivalent??
thoughts?
i totally agree. i consider any off the shelf true street compound dot tire to be stock...but that's just my worthless opinion.
Old Dec 31, 2007 | 12:27 PM
oldgixxer's Avatar
'05 C55(sold)'05 E55(sold)'06 911C4S(sold)'06 ML350 '06 CLS55(sold),buncha slo bikes
What qualifies as "bone stock" has been an age old argument amongst racers.IMO,100%bone stock is the way the car came off the dealers lot.Different tires(i.e.-stickier compound to aid traction)is considered a performance enhancing mod in the eyes of the street racing crowd in my area that I've known for the last 20yrs,as you now hold an advantage over a 100% bone stock vehicle and that's grounds for negotiation at the starting line.
Also,18" wheels are better for dragracing then 19"s,so switch back to them when you head out to race.
That being said,I would like to see if a stickier set of tires will give me the 1/10" I need to get into the 11's
Old Dec 31, 2007 | 12:42 PM
(i.e.-stickier compound to aid traction)is considered a performance enhancing mod in the eyes of the street racing ]
So if I use Drag Radials will I end up on the Mitchell Report
TopGun32's Avatar
stock engine with DR's... not bad 117. Where you able to duplicate this trap a few times?
The cool air really helps the 55k engine.
technically I have a stock pulley.. but it has a bigger ring around it. (j.k)
Old Dec 31, 2007 | 01:19 PM
No, I wan't to run DR's but wanted to know if I would be considered stock.
on the day that I went to the track I ran over 117 on 3 different runs on street tires. I also ran 3- 12.2's and 3-12.3's and 2-12.4's I only ran a 60' under 2.0 twice. 1.96 & 1.97 both of these runs ended up 12.25 & 12.26.
Old Dec 31, 2007 | 02:48 PM
MB_Forever's Avatar
I agree.......
To be considered 100% stock means exactly as the term implies, 100% factory condition with no modifications or changes what so ever. So you'd pretty much have to run the car with all the equipment it had when it was shipped from the factory with no modifications at all. However, if you run on drag radials, then as Enzom suggested, you'd be considered "stock on drag radials" or if you run using different rims, then you'd be considered "stock on different rims". You are still considered somewhat stock, but just not 100% stock.
Old Dec 31, 2007 | 03:07 PM
OK so next time out I will have to follow up with what I have already run or beat it. I think I will beat it. In talking to Enzom I had my car set up wrong that day. I had my setting on C instead of S which could have cost me either at the start ,middle or end and my 19's are little heavier than the factory 18's. If can heat the stock conti's up and they prep the track and pump up my front tires to 40lbs I just might break into the 11.9x range
Old Dec 31, 2007 | 03:31 PM
MB_Forever's Avatar
Also remember that track prep was really bad that day. So even given the exact same setup you had last time but with better track prep, I believe you could've gotten 12.0 easily.
Don't worry though, this time around (our next track rental), Adam will make sure we have adequate VHT and track prep. So whatever setup you choose to use, I'm sure 11.9x is on the horizon or maybe even 11.8x
Let the games begin........
