Drag Nittos On E55
2004 e55
Drag Nittos On E55
Thinking about running at set of 275/35/18 drag nitto on the rear of my e55 and was wondering if anyone on here has tried or is using this tire? Was not planning on switching out with different tire for the street staying with the nitto on all the time. I don't use the car for every day use. I used this same tire on my lightning truck with great results. Picked up 2 tenths over the goodyear F1's.
Good luck.
2004 e55
I know the BFG's are a little more stickier but don't want to be picking up every piece of road dabree. No problems with the 285's rubbing? or fitting the stock wheels? Do you still have traction problems with the nittos is that why you want the BFG's? Thanks for the input.
You are right about the BFG's picking up everything on the road when used for daily driving. It just SEEMS the BFG's have a stickier compound than the Nitto's.
I can't really give you a definitive answer between which is stickier on the track yet...I'll go through these Nitto's and then get a rear set of BFG's to see what if any effect they have on the track.
2008 E63
I just put 285's on mine. No problems rubbing at all. The Nittos are much stickier than the Contis, but I still can light them up if I just mash the throttle ESP off. I haven't tried them at the track yet, but they can't be worse than the stockers.
I'm interested to see how long they last....
I ran Nittos on the rear of my E55 and felt they were awesome for daily driving in warm weather (and even rain they were okay). I have also had the BFG drag radials and they are not going to last as long as the Nittos, plus they did pick every piece of road debris off of the road! I think it goes like this:
-Stock Conti's: ok daily driving, not so good for drag racing
-PS2's: great daily driving, better for drag racing
-Nitto DR's: good daily driving, even better than PS2's for drag racing
-BFG DR's: not good daily driving, best for drag racing
I have no experience with the Micky Thompson DR's but have heard from my Vette buddies that they are even stickier than the BFG DR's.
Hope this helps.
PS: I think that PS2's, Nitto Invos, or Nitto DR's are perfect for daily driving in non snowy areas of the US.
Hope this helps.
2003 E55 AMG
The smallest 18" radial Mickey Thompson makes is a P305/35R18. Do you all think it would fit and clear on a stock 18" wheel on a car thats not lowered? I know this tire would be unbelievable for the track but dont know for sure if or how bad the rubbing issues would be. Maybe someone here could chime in and let us know if they have tries it and what the results are!!! BTW, I have had great success out of NITTO 18" D.R. on Corvettes and Vipers. I have cut consistant 1.65-1.70 60's on a C5 vette and been in the low 1.50's to 1.60's in a SRT Viper this past year
2003 E55 AMG
Well I got the size options straight off of mickey thompson's web site and those sizes are'nt listed. If that is the case maybe they make diff. sizes and ones in a 275 or 285 that would be perfect for our cars on stock wheels!!!
ET Street Radial
Optimized For Modern Sports Cars & Sport Compacts
Mickey Thompson's legendary race tire technology comes to the street with all-new ET Street Radial. Built using the latest in high tech radial construction techniques and years of drag racing experience and compound development, this D.O.T. approved street legal drag radial will get your car down the track in record time and drive you home with sure handling and an excellent ride.
Soft Compound For Superior Traction On The Drag Strip
Radial Construction for Excellent Ride Control on the Street
Low Void, Directional Tread for Maximum Dry Traction
Tubeless
Acceptable practice for rim width is tread width plus or minus 1''.
CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle.
† Specs are estimated, availability to be announced.
Click to Enlarge
Part # Size Size
Equivalent Appx.
Weight Compound Approved
Rims Measuring
Rim Sidewall
Width Tread
Width Overall
Diameter Circ.
3750R P205/50R15 23 X 8.0R15 22 R2 5.5-7.5 6.5 8.42 7.6 23.13 73
3751R P225/50R15 24 X 9.0R15 23 R2 6.0-8.0 7 9.11 8.2 23.98 75.3
3795R P315/45R16 27 X 12.50R16 34 R2 10.0-12.0 11.0 12.6 11.2 27.2 85.5
3794R† P295/50R16 28 X 11.50R16 33 R2 8.0-10.0 9.5 12.1 10.8 27.7 86.9
3744R P315/35R17 26 X 12.50R17 31 R2 11.0-12.0 11.0 12.7 11.7 25.78 81
3745R P295/45R17 28 X 11.50R17 33 R2 9.5-11.0 10.0 11.6 10.6 27.2 85.4
3785R† P305/35R18 27 X 12.50R18 31 R2 10.0-11.0 12.0 12.5 11.5 26.39 82.9
3788R† P345/35R18 28 X 13.50R18 35 R2 11.0-13.0 12.0 13.89 12.8 27.5 86.3
ET Street Radial
Tubeless
Click to Enlarge
Part # Size Size
Equivalent Appx.
Rims Measuring
Rim Sidewall
Width Tread
Width Overall
Diameter Circ.
2003 E55 AMG
yup I see that!!! I went out and measured my stock cont's and they were right at 25" in height. I think that tire would be pretty good for 60ft. times but street wear would totally suck
Guess it depends ultimately what you are wanting to use it for. I would like to find 2 rear stock 18" amg wheels just to run at the track or when I knew I would be messin around on the street b/c I know whatever it is under track conditions is not gonna last too long with me
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
mate of mine (member on this board) got him self nitto invo 305 19 on his rear 19's cls AMG rims n from a dig on the streets they showed a difference of two car lengths on me, simply because i could not get any traction and he could.
Woud really like to give them a try my self but hoping for 295 18
2004 e55
I live in Chicago but don't drive the car 7 months out of the year. It sucks but if you want to keep the car mint that's what you have to do out here. I will let you guy's know the ET'S and 60ft times when I go to the track in stock form and modded form. I have michelin pilot sport tires on the car now with no mods. Will run it first like it sits, then put the nitto's on it and run it again the same day and let you know the results. Then I will put on the VRP pully, code 3 bigger intercooler,k&n filters, jhonson pump, reprogramed ecu, and run it again and let you know the results. I know I should do each one and see the difference, but can't wait that long sorry.
You need to "break-in" the Nittos before you can expect decent results. Depending on who you listen to, it takes between 250-500 miles to burn some lubricating chemical off the tread surface that is used in the manufacturing process. So if the Nitto's are brand spanking new when you test them, it won't really give you a fair comparison.
PS...I'm looking into getting a 16" rear setup with Mickey Thompson drag radials...will the break-in process be the same?
Enzom...can you just do a couple of burnouts to run through the lubricants. I bought my DR's and had them sit in my garage until I used them last week at the drag strip and plan to only use them at the drag. I change into my 19" setup after I get back from the track.
2003 E55 AMG
Check it out, they have updated their website with a bunch of different sizes in 18's!!!!! This is the tire I am definetly going with![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
http://www.mickeythompsontires.com/s...ETStreetRadial
For track I have 17 275/40...
Anyone knows if any tyre maufactures going to make some DR or semi-slick for 19 wheels 275-285/30 ??? I would love to have something like Toyo 888 on my rear for street racing...
