How would the E55 sound with a straight pipe from resonator/xpipe to tips?
Old Feb 6, 2008 | 07:52 AM
Blacksport350's Avatar
Formula Mazda, Beast Junior...400HP 135i
Originally Posted by mbamg06e55
Here you go. These are what I use.
https://shop.quicktimeperformance.com/cart.php
How did you plumb them in to make it clean? If someone is using them frequently (especially when sitting in traffic), I would want to see the exhaust properly exiting the underside of the car and not just dumping underneath it.
That being said, you could do a trick setup with some custom mufflers running through one set of tips and the bypasses running through the other set of tips. It would be tight to fit it all in but it could be done.
I had always thought of trying corsa mufflers on an AMG:
http://www.corsaperf.com/
On an LS6, they are quiet at cruise with a throaty but quiet idle. When you add throttle, all hell breaks lose in a very big way and the sound is AWESOME!
It was the best sounding exhaust I have had on any car including an F car with a nice setup.
Old Feb 6, 2008 | 02:40 PM
uthustler's Avatar
2006 E55
Originally Posted by LazyE55
Once i get my car back I'll get a recording. I opted for the K2 program without the cats so I'm not throwing any codes.
What is the K2 code?
Old Feb 6, 2008 | 02:41 PM
uthustler's Avatar
2006 E55
Here's a sound clip right before i removed the remaining cats(Secondary). Basically it's the Kleeman headers, Primary Cats Removed, Secondary Cats Intact, Resonator Delete, and Eisenmann Race exhaust
http://youtube.com/watch?v=mClNpdsapjU
what cats can I delete and now throw codes?
Old Feb 6, 2008 | 02:43 PM
uthustler's Avatar
2006 E55
what corsa muffler would you go with?
Old Feb 6, 2008 | 05:34 PM
THat is a good question as they don't really just supply the parts as they tune the mufflers for the specific systems.
Old Feb 6, 2008 | 07:18 PM
LazyE55's Avatar
E55
Not shure ...but all Kleeman does from what i hear is that they turn off the 02 sensors in the ecu....i could be wrong but that's the way i know it as
Old Feb 6, 2008 | 07:19 PM
  #32
LazyE55's Avatar
E55
As long as you have the primary cats intact it won't throw any CEL codes. So just remove the secondary cats and you should be fine. Before i had the K2 upgrade i had the secondary cats removed and it didnt throw any codes.
Old Feb 6, 2008 | 07:23 PM
  #33
uthustler's Avatar
2006 E55
well I straight-piped it today from the front cats back and man, it sounds like pure sex. Only problem I have now is that at 1800rpm (70mph) cruising there is a sweet spot drone. So I gotta put some mufflers back on.
Problem is, I am not gonna pay $2500 for mufflers. So does Borla or any other manufacturer have mufflers that sound good, little louder than stock but not obnoxious? (yet still under $1500)
Any suggestions?
Old Feb 6, 2008 | 08:58 PM
  #34
blackbenzz's Avatar
haters crazy
Any suggestions?
Where's the vid?
Old Feb 6, 2008 | 09:16 PM
  #35
uthustler's Avatar
2006 E55
If I were to go Borla, which of these model #'s is the correct one for our E55's?
http://www.borla.com/products/product_multi_detail.aspx?cat=2&type=43&desc=Unive rsal+Mufflers%2c+Tubing+%26+Hardware|Turbo+Muffler s
Part # Inlet Diameter Outlet Diameter Case Size Description Price
40651 2" 2" 13 1/4" x 4" x 9 1/2" Center/Offset $126.99
40657 2" 2" 14" x 4 1/4" x 7 7/8" Center/Offset $160.99
40652 2 1/4" 2 1/4" 13 1/4" x 4" x 9 1/2" Center/Offset $124.99
40981 2 1/4" 2 1/4" 13 1/4" x 4 1/4" x 7 7/8" Center/Center $154.99
40658 2 1/4" 2 1/4" 14" x 4 1/4" x 7 7/8" Center/Offset $163.99
40653 2 1/2" 2 1/2" 13 1/4" x 4" x 9 1/2" Center/Offset $124.99
40659 2 1/2" 2 1/2" 14" x 4 1/4" x 7 7/8" Center/Offset $162.99
40980 2 1/2" 2 1/2" 13 1/4" x 4 1/4" x 7 7/8" Center/Center $175.99
Old Feb 6, 2008 | 09:17 PM
  #36
uthustler's Avatar
2006 E55
Originally Posted by blackbenzz
Where's the vid?
I dont have a video camera. If you know someone in dallas that does, let me know and we can go get a vid.
Old Feb 6, 2008 | 10:28 PM
  #37
uthustler's Avatar
2006 E55
does anyone know a place that can gut or mod the AMG stock mufflers?
Old Feb 7, 2008 | 03:34 PM
  #38
III II I I AMG's Avatar
2003 e55
man, just get cutouts like i am..
Old Feb 7, 2008 | 03:39 PM
  #39
uthustler's Avatar
2006 E55
yea thats what Im doing, where did you buy yours?
Old Jul 28, 2008 | 07:12 PM
  #40
aleksandar1099's Avatar
Top Answer: 1
Mercedes
did anyone ever get a vid of an e55 with cutouts or straight pipes
Old Jul 28, 2008 | 08:32 PM
  #41
BenzoBoi's Avatar
Super Moderator
W221
Any suggestions?
Let me try to find a video of my set up. I have taken out the resonators and put a borla race muffler...sound of the peeps in socal have heard it. I think it has a nice lil rumble to it...
I was thinkin about puttin a x-pipe where the resonators once were so I can get rid of this one spot with a lil drone. Other then that I think it sounds awesome....I'll try to find the video...
Old Jul 28, 2008 | 09:07 PM
  #42
bobgodd's Avatar
2004 E55
I have actually thought about throwing Corsa mufflers back there also!!
I even wrote them an email asking them if they would consider making a system for our cars... Especially seeing as how they now have a system for the M5!
Best sounding muffler by far.
Old Jul 28, 2008 | 09:18 PM
  #43
supre55's Avatar
E55
Talk to chiromikey about Corsa mufflers for our cars. He researched some time back
Old Jul 28, 2008 | 11:24 PM
  #44
BlackHammer's Avatar
2006 E55
I did the Xpipe mod (resonator delete) and have a little more noise but not near what I was wanting, so wondering what to do next.
"SPM" (Straight Pipes and Mullets) is where this is heading, boys!
You might as well get yourself a big pick-'em-up, throws some duals aka "cannon's" on the back, put a Confederate flag in the rear window, and hell; maybe even a "**** on BMW" picture doing this kind of bs...
In Minnesota this is a common scene (SPM) and it just makes me ill to think of an E55 sounding like that.
T
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
