simple exhaust question...
E55 then E63, now back to an E55
I don't care about the HP but want slightly louder sound. Heard the resonator delete causes cabin drone (which I definately DO NOT want). What should I do that is fairly inexpensive and easy? Thanks......
I have removed the resonator in every AMG that I have owned and not been disappointed.
'06 E55, '05 SLK55, a few others
Actually, deleting the resonator cured a 72 mph drone I was getting from the stock exhaust. It's not the cheapest way to go, but I used Evo's resonator delete setup and am very happy with it. Just a little more noise, zero smog issues, and no effing drone in the cabin at freeway speeds.
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
#33
2005 E55
#38
most muffler shops have this material handy...
stainless steel and you can coat with anything else you want to make it looks even nicer.
$70 per piece is probably about right.. if you go to a low end neighborhood is probably $35 per piece.
its only a pipe and welding people.. nothing more than that.
If you have a leak.. then bring it back and they will fix it.
#39
'03 E55
To me, the sound that you get is really ideal. My wife was in the car for about 20 minutes after I had this done and she never noticed a difference until I got on the gas pretty good. The sound is just a little deeper than stock until you step on it.
#40
1 Post
Sorry if I'm duplicating my questions but I didn't receive an answer from anyone. Will deleting the secondary cats have any affect on emissions and smog??? CA emissions are really strict and wondering if anyone has the answer. Thanks!
#42
Deleting the cats is not legal for Ca. Whether or not your local smog place notices is another matter. You will pass the tail pipe test, but fail the visual if they notice. Neither that or the resonator delete will give much power on a W211. As for the Evo resonator kit, it was $159.00 when I bought it while having other mods done. It is stainless and very high quality. Is it over priced? Probably, although the install looks as if it came that way from the factory, unlike the pics you see of these other cars (nothing against the $79.00 exhaust work).
#43
1 Post
