E55 Virgin... What is the best food to feed this beast?
Just got my beast and i want to make sure i keep him to a clean healthy nutritional diet. Thanks in advance!
Never heard bad things about Sunoco.
Few have tried Sunoco 104 but we have found that mostly it does not help and that ECU can't hang with that much octane.
I've tried investigating the legitimacy of this site and so far have not been able to prove it's a hoax. Some of the language they use on there from a technical standpoint makes sense, so whenever possible, I try to use these stations. I use shell 99% of the time.
http://www.toptiergas.com/retailers.html
-m
-m
i've been only using Mobil gas since i don't like mixing gas....
i guess i will stop using them if that website is accurate about the list
I used to use Chevron all the time.... but recently switched to 76 as some members suggest. Non-brainer for me.... around here 76 is cheaper
Major garages here have the following High Octane fuels:
Shell - Optimax98 /Helix98. Shell Racing 100 RON
Mobile - Synergy 8000. 98 RON
Caltex - Vortex 98
BP- Ultimate 98
I filled up with Shell Racing 100 RON today. If I was somewhere where I was on empty and had no choice but to fill up with 96RON I would put $5 bucks worth in the tank to get me to a garage with a better fuel. I consider 96 RON or less in my tank a contaminant!
Question. If you guys with ECU tuneups tuned then with a low octane fuel in the tank, the car would in theory run at its best with that particular fuel wouldn't it?
(OK may be not that extreme....
).Or... the price difference could give us enough money to buy race fuel for live (105+
With the fuel issue I didnt think it was a dollars thing. Its more an environmental Al Gore thing... isnt it?
You guys in OZ use the RON rating for octane, and we use the average of MON and RON. Essentially, our 93 octane rating is the same as your 98 octane rating.
Common misperception, we aren't hurting that bad
-m
So needless to say, I use only Chevron with Techron
most of the online "gas gurus" believe it has the highest quality additives.If it's not available, I use Shell.
Mobil products are trusted by Mercedes-McLaren for their Formula 1 cars... so, I ask again: why not Mobil? (see pics of MP4-21, 22 and 23 below)
BTW, there are some brands on that list that i have never heard of...
4 web pages and no contact information is all I need.
All they can do is quote from existing classification societies.
You are right Mobil is a respected fuel and I would have no problem running it.
No brag but I have responsibility for many different gasoline powered vehicles, boats, bikes, ATVs & Gen sets, and have tried many fuels over the years. I have found that some of the lesser used "toys" would need fuel system cleaned on a annual basis, most showing large amounts of gum and varnish. This occurs from fuel evaporating and fuel becoming stale, the solids in the fuel clump together and clog the fuel system. In most cases the idle circuit would clog first in the carburated machines. Then one day I tried BP ultimate 93 the (clear) fuel in the "fleet" and have not had one issue with clogged fuel systems since and that has been 4+ years.
Dose this make it the best? no, It only makes it the cleanest, and may not require any detergent additives. As you can see Top Tier is all about more detergent in the fuel, and nothing wrong with that, I just prefer the fuel that dose not need it.
Yes Techron works very very well and I'll stand by it's claims, I have used gallons of it in the years past, but I don't need it any more.
STAY AWAY FROM ALOHA GAS
