SDS, Star Diagnostics Mods?
Old Mar 4, 2008 | 08:46 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Question SDS, Star Diagnostics Mods?
Going to the dealer this week to get some SDS work done.
1. Xenon Present
2. 10 Degree Fan
3. Phone/Bluetooth Present
4. Lower DC Airmatic
Anything I am missing here?
Old Mar 4, 2008 | 09:15 AM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Wanna feel something cool, have him clear the tranny adaptations while you are there. Car will feel totally different after.
warning*** Shifts are more aggresive for a hundred miles or so. Some guys hate that and like the smoother feel. I like um punching me in the back.
Old Mar 4, 2008 | 11:33 AM
vrus's Avatar
2003 E55 AMG
You can also enable the "Fuel Capacity remaining" option..
And I like disabling the auto-raising of headrests when the seat is moved backwards.. drives me crazy!
Old Mar 4, 2008 | 11:59 AM
W219CLS55's Avatar
06' E55, 10' Harley Davidson F-250 6.4L TT
Fuel Capacity remaining?
how does that feature work?
Old Mar 5, 2008 | 07:51 AM
I'll do it, Thanks Victor.
I am on west coast (FL) now and will be stoping by C2D on Friday, Chris says hi.
Old Mar 5, 2008 | 08:37 AM
alltrac's Avatar
2004 E55
1. Xenon Present
2. 10 Degree Fan
what do these mods do (1,2, and 3)? Especially 2 (makes the fan cut on 10deg sooner) and 3?
Old Mar 5, 2008 | 10:30 AM
jangy's Avatar
2015 S212
definitely make the headrest sit still.
I also like to have the position of the driver seat adjusted. As it is, if you use the easy exit feature, it only allows the seat to go back so far (as not to crush lil toes). That location can be moved back for those of us that rarely carry passengers and like to stretch out.
By Xenons, do you mean you retrofitted and need to turn on the functionality? I've heard rumors that the '06 E55 can have the active fogs turned on as well through star. I dunno if it means getting new units or what, but I'd be down.
Old Mar 5, 2008 | 12:35 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
One can also code for the BASIC TPS using the ABS signal
Old Mar 5, 2008 | 01:41 PM
1. I did a Bi Xenon retrofit you can see it here.
https://mbworld.org/forums/showthrea...016&highlight=
2. Yes, fan comes on 10 degrees cooler.
3. 2004 E55 w/Nav have all the hands free items installed and the network that supports bluetooth if you install the puck. To make it work, it must be version coded (turned on) for "phone present" as now the bluetooth puck is the phone.
4. Thats me low rider, going to go as low as the factory camber will allow.
Old Mar 5, 2008 | 03:03 PM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Nice info...
Old Mar 6, 2008 | 05:28 PM
All done Good day!
All done, just a few notes here,
1. Lights work great.
2. Too cold here today to really tell looked 1 bar lower, I need a hot day.
3. The puck with tail works with the I phone, this is big news as wireless for MB says function is unknown, I will do a bigger post regarding this after I fool around with it. Right now it makes calls, receives calls, caller ID, downloaded phone book, nav key board can dial and hang up, the wheel controls work and the MFD displays call information, more to come.
4.Set new ride hight and did 4 wheel alignment, only got 1/4 inch lower and that was all the camber adjustment we had. so if you lower your car much more than stock expect above average wear on the insides of your front and rear tires. Next mod is the eccentric cam & bushing kit and an ELM with toe links of course.
5. Gallons remaining
6. Head rest over ride, man it took me like 20 minutes to find my sweet spot again, (I pushed the memory button)but it is all reset and I now use the entry exit feature too.
Plus Mercedes Benz wants my cats back, Most 04 will get new primary cats. under a service campaign.
Old Mar 6, 2008 | 05:39 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
i should have posted before you went in but was too lazy. can we use sds to allow our steering wheel radio buttons to scroll through our preset stations instead of scanning. that is REALLY annoying!
Old Mar 6, 2008 | 06:35 PM
Thanks, never too late, I may try this
http://www.gnetcanada.com/navvideo-m...b2x_mbw211.asp
With the I pod intergration kit and there are some scrolling issues when you have 100 movies and 10,000 songs
I'll start my notes now, thanks Mikey.
