50K mile Service
E55
50K mile Service
Hey guys,
what is the recommended 50K mile Service? I have 48K now and i want to avoid getting raped again at the dealer ... does anyone know what they typically do/check at 50K??
2005 E55 ///AMG
I have some stuff for the dealer to install (New MP Design Wheel and 160* Thermostat) as well as the usual oil change. Think I will get them to drain and fill the tranny fluid and the brake lines along with inspecting the brake pads which should be close to needing replaced although they are making no screeching noises.
You should also have a full inspection of wear and tear items (brakes, suspension, hoses, belts). I would throw a supercharger belt on if it were me as they are cheap and quick to do.
Beyond this, the only thing open for debate would be the plugs and a power steering fluid refresh.
2007 E63 w/P30 and Eurotech CF Diffuser
So I guessing you have lost you maintenance manual??? Dripping sarcasm.
You can go to MBUSA owners online and register with your VIN number and then you can download this booklet.
ANYWAY, from the 2007 E-Class booklet
Which is the same thing they do at 10K miles
Service 12, Change oil and filter
US Service 13 - first at 10,000 miles or 1 year; after first every 20,000 miles or 2 years
Engine compartment
Check catch, safety catch and hinges on engine hood for proper operation 8851
Check the following fluid levels, correct if necessary.
If there is a loss of fluid, determine cause and perform repair with separate work order
Brake system 4210
Power steering 4611
Windshield washer system (incl. summer/winter cleanser) 8210
Interior
Reset maintenance service indicator in instrument cluster 0042
Function check
Warning/indicator lamps, illumination and interior lighting - - - -
Windshield wipers, windshield washer system, headlamp cleaning system, where applicable: rear window wiper, rear
window washer system
8252
Wheels, brakes
Inspect tires for damage and splits, measure tread depth and record in mm 4051
Check condition/thickness of front brake pads/discs (remove 1 front wheel) 4251
Correct tire inflation pressure - - - -
Trunk
Check battery condition using “Midtronics MCR 717” tester 5453
Check trunk lighting - - - -
Check TIREFIT sealant expiration date (wagons with third row seat only) 4045
Vehicle front/rear
Check wiper blade condition 8253
Engine compartment
Brake system 4210
Power steering 4611
Interior
Function check
8252
Wheels, brakes
Trunk
Vehicle front/rear
2005 E55 ///AMG
Show me in the manual where it says 'This is what others that have reached the 50K milestone have seen as problems that will/can occur in the nest 15K miles and to get the dealer to fix these potential problems BEFORE the car is out of warranty" in the manual.
/sarcasm off
Seriously, this is a forum for members to share right? We were not asking what the MANUAL says as we all know that and our stealership will be more than happy to do those services. We were just interested in what may go wrong in near future and what to have them check NOW while under warranty.
Thanks for the suggestions guys.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2005 E55 ///AMG
As a followup, let me tell you the things I had done at the stealership...even with a good relationship with the SA and 10% off parts and labor...$1431.21. ![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Now the list:
1 - Upgraded IC pump - Warranty.
2 - Check all seals/doors/trunk/etc for cracking/creaking and lubricate - Warranty.
3 - Lug bolts replaced after some being found rusty - Warranty.
4 - Intermittent wiper was too sensitive. They reset windscreen adaptation. Warranty.
5 - Full electrical system check including both batteries. Warranty.
6 - Command/Audio System Firmware update. Warranty.
7 - Clean sunroof tracks and lubricate latches including doors/trunk/hood. $52.50.
8 - Remove K&N Filters and blow out all dust/etc. $ 31.50.
9 - Transmission/converter drain and fill. $ 245.40
10 - Rear end differential drain and fill. $ 116.50.
11 - Install PTE 160* thermostat and -10* fan mod. $ 136.50.
12 - Fuel Filter Recall. Warranty
13 - Check pads/rotors, drain/flush entire brake system and refill. $ 157.50.
14 - Sirius SAT module install (I provided the module), they had to order bracket and custom antenna for trunk. $ 646.60![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
15 - Install Stealth Auto 8000K bulbs. $ 52.50.
16 - Oil and filter change (I provided the AMSoil for them). $ 83.26.
Hope this helps for those that may be getting to the 50K mile mark.
Now the list:
