Toe-links....
Old Mar 20, 2008 | 03:21 PM
jangy's Avatar
2015 S212
Originally Posted by theboogers
suppose you have wiggle in sl not just e class and the offset and tires are same as stock? i think the toe links and a lsd may be the answer, no?
maybe. the issue isn't just with the E. It is on all 55s. Interestingly enough, the S has stronger arms, but that was likely designed for weight, not stress.
Old Mar 26, 2008 | 12:55 PM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
any one got pics of these things so we can all have a look please ?
Old Apr 5, 2008 | 08:41 AM
E55 RUSS's Avatar
E55K
Originally Posted by chiromikey
from what others have described, it's when the car erratically shifts from side-to-side but is NOT losing traction. apparently it's enough to make some cars very unstable and hard to keep going in a straight line.
Well my car does like this but it doesnt bother ME..too much power I guess...
It been sometimes since I looked at this thread...those who insaleed toe-links recently...what are your conclusions ???
Old Apr 5, 2008 | 11:30 AM
m52e55's Avatar
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
having done now. will update next week as tl's are complimenting move to RT stage 4 & ic system upgrade.
Old Apr 5, 2008 | 11:58 AM
ENDSMTG's Avatar
'08 S65, '04 Range Rover(The House), '06 Lexus GS 300(Wifey's), '02 Sea Ray 360 Sundancer
Got camber kit installed! No Toe links. Car runs straighter than before. No more tire wear from this point either. Installer told me he left it at 1 degree of negative camber. Looks great and is riding great!
Old Apr 5, 2008 | 12:42 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
...so where did you get them and how much?
Old Apr 5, 2008 | 02:20 PM
  #32
dkallencat1's Avatar
I went from the stock 18's to the 19in. sl 65 rims with Ps2, 275 in the rear and I notice alittle wiggle when I get on it hard, and I did not have that problem with the stock setup. It's no big deal to me, I just live with it.
Old Apr 5, 2008 | 03:21 PM
  #33
E55 RUSS's Avatar
E55K
Why no toe links...How does it look compared to before ???
How did he leave 1 degree negative camber ???
  #34
E55 RUSS's Avatar
E55K
Renntech...you can get them from James@creative for 1100 I think...
Old Apr 5, 2008 | 03:23 PM
  #35
chiromikey's Avatar
not the toe links...the adjustable camber arms.
Old Apr 5, 2008 | 03:44 PM
  #36
E55 RUSS's Avatar
E55K
I think its comes in a package
Old Apr 5, 2008 | 07:22 PM
  #37
chiromikey's Avatar
hmmm...are you sure?
Old Apr 6, 2008 | 12:51 PM
  #38
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Renntech now only offers a package with the toe links and camber bushings. I had to pull strings to get half the package. I will try to take some pictures on an SL, but the camber bushings aren't visible. They function well though.
Old Apr 6, 2008 | 01:09 PM
  #39
E55 RUSS's Avatar
E55K
Where did you get half kit and how does it work ???
Old Apr 6, 2008 | 01:25 PM
  #40
nick 55's Avatar
I work closely with an authorized dealer, and only needed the camber bushings, not the toe links.
Old Apr 7, 2008 | 04:27 AM
  #41
E55 RUSS's Avatar
E55K
Can we get them from him as well ???
Old Apr 7, 2008 | 09:39 AM
  #42
ENDSMTG's Avatar
Looks great! The camber is adjustable. Nick 55 did it for me. I see he has already posted to your reply. Works great so far, with no "wiggle"!
Old Apr 7, 2008 | 03:26 PM
  #43
E55 RUSS's Avatar
E55K
Does the car hooks up better ???
Is your loweredd or not, is there ride height diff ???
Do you have before and after pics ???
Why didnt you get toe-links ???
Old Apr 7, 2008 | 06:04 PM
  #44
ENDSMTG's Avatar
Defenitely hooks better! My car is lowered via H & R ELM. No ride height difference after installing camber kit. No pics, only noticeable difference is how the tires sit. Before you could notice the tires were pitched outward. Looked like a pigeon toed kid. Now the tires are perfectly aligned. Was advised that I didn't need the toe links by Nick 55.
Old Apr 14, 2008 | 07:02 PM
  #45
jangy's Avatar
2015 S212
There is a bunch of confusion in here. We are talking about two different parameters, each tweaked in a different way.
We all know I'm not a RennTech fan and that I like handling, so take it for what it is worth.
The Toe links are not adjustable. They are assumed to be the "cure" for the waggle, especially on the highly modified (power and or traction) by being stiffer than the OEM versions. After lots of playing with them, I personally just think they have stiffer bushings. Now, that may solve the waggle. I don't know. To date, I have never seen diffinitive data showing how much the toe arms bend and how much stiffer the RT ones are.
The Camber adjustment bushings are just offset bushings. I am personally not a fan. To me, it is a $5 band-aid on a $100K ride. Just not up to snuff for me.
What is interesting is the one buyer that said he had his car toe'd OUT and liked it better. For me, the car is plenty stable in a straight, even if it waggles. Having the rear tires being toe'd OUT actually helps with turn in, so I think some of your new found joy may have simply been an alignment issue.
The car comes basically neutral on toe. I usually keep mine neutral in the front and slightly toe'd out in the rears.
Old Apr 14, 2008 | 07:36 PM
  #46
steadi's Avatar
E55, Audi S4
Not something that I'd suggest on a street car.
With Toe the car is ALWAYS going to go in the direction of the most heavily loaded wheel.
Using toe to increase turn-in is a band-aid. You want the car to turn in better? Add camber and caster to the front and reduce camber at the rear. You can also play with tire pressures. But stay away from rear toe out on a rear wheel drive car.
Old Apr 15, 2008 | 02:42 AM
  #47
E55 RUSS's Avatar
E55K
I am confused...
Old Apr 15, 2008 | 05:58 AM
  #48
steadi's Avatar
E55, Audi S4
I am confused...
what's to be confused about? Toe out at the rear of a rear drive car is a BAD idea
Old Apr 15, 2008 | 02:39 PM
  #49
E55 RUSS's Avatar
E55K
So its not good to get those parts mentioned above ???
Old Apr 15, 2008 | 09:57 PM
  #50
jangy's Avatar
2015 S212
Are you serious? I was raised that way. Holy cow, I had no clue it was so bad. It worked wonders on my M3, band-aid or not.
The things you mention for improvement have already been maxed. the car is a pig and not a rear engined sports car.
At any rate, to each his own...
