New Renntech ELM question
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
1 Post
'04 Silverado Z71 - sold all my Benzes and need another!
Noooo, lol, I was at $700 and your buddy came in at $900 which pushed Mike and I out (we were bidding against each other, lol). Then when I glanced at the paper at the end he changed it down to $800 without anyone looking, lol.
2006 E55
Yeah, Im sorry. I never did a silent auction before. For some reason I thought it was ebay.. After I thought about it, I went back and changed it. Some people had crossed their bids out on other items, so I thought it would be OK to change it. In my defense though, they did give plenty of opportunity to bid before closing it off.
But I would have bid it to $1K anyway. Even at $1K, still a steal, and all to a great cause. I wish I could get all my mods this way, if so, I would be completely tricked.
1 Post
I agree, you got a great deal and it all does go to charity in the end! I won the CF E55 front lip for $200 bucks so I'm still content, lol...
#32
#33
2015 S212
Not sure whether this should answer it....
If I read the instruction manual (http://www.renntechmercedes.com/lm_i...ions/mb_lm.pdf). It seems that up W211 up to 4/06 build date has 4 sensors vs. 3 sensors on 5/06+ build date
Dunno where you read that, but it is not true. i have been all over the W211s and haven't come accross a 4 sensor yet. Again, that is airmatic. ABC has 4 sensors.
You're right, reading the instruction, it seems that you basically just move the wire... so instead of naked wire-to-wire connection, it would just use an adapter that has to be connected manually? Why can't R/T create a true PnP?
#35
2006 E55
wait, our cars only have 3 wires? I wired mine for 4 wires because of the instructions. So are the instructions incorrect?
My assumptions: 2003-4/06 were 4 wire
from 5/06 on, they were 3 wire.
Someone please clarify!
#36
#37
can an indie fix this with the sds system ? its off not more than a half inch... didnt have exactlly level ground but the car appear a more level when the elm was off ...
other than measure on a total level floor in the day time any help would be appreciated
#38
i have the same problem driver side rear sits lower than passsenger rear... my settings were 3/3/6 indie found sds error code for front driver side mb airmnatic leveling sensor. took it to dealer for free replacement and fuel filter recall with the elm turned off and they said they reset it.... got home turned the elm on and back to the 3/3/6 setting and the rear driver side is still off...
#39
#43
mine is 3/3 front and 6 rear. i thought for the airmatic there are only 4 knobs... 2 for front ,1 for rear and next to that the rear an on off knob which is numbered as 0 for off, 1 for airmatic and 2 for the non airmatic..... i was told the following... either the leveling sensors for the airmatic are faulty /going bad and need replacement and or they need to be reaclibrated if they are off... my idie did it in less than an hour.....
#44
#46
2006 E55
#47
2015 S212
I don't claim, it is simply impossible. ABC has a sensor at each wheel. Airmatic in the E55 has one at each front and one in the center of the rear. There are no other sensors. I do not know how the new S runs on Airmatic. the older S never had it. they all had ABC.
I do not know if RT's manual is incorrect, but I think I remember that the last set of instructions mixed up some colors with the wire numbers. I also think i remember someone with the new one saying that the colors are off on the new one, too.
#48
2006 E55
I'd check that, charles. Your Airmatic only has 3 sensors.
#49
2015 S212
They could be power buttons? I dunno. All I am sure about is the number of sensors and that the new S has Airmatic as well (but it may be different).
Did your elm work? With the older one, there are two different "on" settings to determine which setup you have. In all honesty, I don't think it made a difference in my car which on it was on, as long as the 3 sensor wires were on.
