SLR Supercharger???
Old Apr 4, 2008 | 06:06 PM
ATKM5's Avatar
2005 Mercedes G55 AMG
SLR Supercharger???
Remember those Atilla E55 videos where he was smoking 600hp Porsche Turbos, M5s and M6s? Here is a link I came across:
http://www.youtube.com/watch?v=uQXtO...eature=related
In the comments section they mentioned that Atilla has an SLR supercharger on it...
What is the difference between our supercharger and the one in the SLR???
Any input???
Old Apr 4, 2008 | 06:13 PM
Murtaza's Avatar
C63S coupe, X5M
The SLR supercharger is loud as hell, can't hear it at all in those videos...
Old Apr 4, 2008 | 06:16 PM
cls55's Avatar
slr
iternal gears are diffrent.
Old Apr 4, 2008 | 06:29 PM
ATKM5's Avatar
How much more power will it give to the E55 if they are swapped?
Old Apr 4, 2008 | 06:35 PM
Jakpro1's Avatar
2003 E55 & 2014 GL550
Don't quote me on this, but SLR supercharger is supposed to have different ports on the sides to support the top mount SLR intercoolers.
Be cool to just get parts off it as all we need are those front gears to overdrive it.
Can't though.
Old Apr 4, 2008 | 06:40 PM
ATKM5's Avatar
Are our superchargers portable, can we port them like the Jags do?
Old Apr 4, 2008 | 06:43 PM
tommy25000's Avatar
2005 E55
I also wondered this... I ported my Cobra blower and go 50hp at the wheels
Old Apr 4, 2008 | 06:48 PM
dsc's Avatar
dsc
2004 E55
Do a search porting has been done on them. I believe Finny did it.
Old Apr 4, 2008 | 06:59 PM
tommy25000's Avatar
2005 E55
I know with some setups porting can actually make you lose power and tq
Old Apr 5, 2008 | 02:33 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
alas we have heard nothing from him since...
Old Apr 5, 2008 | 03:00 AM
Havoc's Avatar
2005 E55 AMG - - 2005 SL55 AMG - - - - - - 2006 SLK55 AMG - - - - - - 2013 Ducati Diavel AMG -
Hey guys, I'm trying to mod my 55 Kompressor all that I can, including porting or replacing my blower. I wanted to port it out but I was told that porting our blowers is not worth much power. Some blowers will benefit, but I guess our Kompressors will not benefit much, if at all. For now I will port match my lower intake manifold with my stage 3 heads and see how the blower will act with the addition of twin turbos. Nevertheless, I'm still looking for the best solution than just a larger pulley. I want a bigger blower even if this twincharge system will work.
Old Apr 5, 2008 | 03:42 AM
E55 RUSS's Avatar
E55K
Its loud cause TOP MOUT IC....You should hear CLS with that set up...LOL you start to get headache after a while...its louder then exhausts...
Old Apr 5, 2008 | 03:44 AM
E55 RUSS's Avatar
E55K
Yes...too much flow will loose BOOST...need to be carefull with this...
Old Apr 5, 2008 | 04:28 AM
steadi's Avatar
E55, Audi S4
Not true. You want the intake to have the least restriction possible.
Old Apr 5, 2008 | 05:33 AM
E55 RUSS's Avatar
E55K
If its designed for this flow...
Old Apr 5, 2008 | 05:38 AM
steadi's Avatar
E55, Audi S4
If its desined for this flow...
What does that mean?
Old Dec 12, 2009 | 09:34 PM
Fabio D's Avatar
210 55
This guy ATILLA not change the supercharger it self he change all the engine by the SLR one
Fabio Daniel
Old Dec 12, 2009 | 09:48 PM
V12Godspeed's Avatar
Your worst nightmare...
Fabio Daniel
I knew something had to give....his car was incredibly fast! No wonder he was smoking everything that moved.
He swapped out the entire engine for and SLR motor? How do you know this? If true great info.
Old Dec 12, 2009 | 10:10 PM
Forrest Gump 9's Avatar
shrimp boat
Wow, this "Atilla E55" is nuts!!
Old Dec 13, 2009 | 04:01 AM
fredxxx's Avatar
E55 211
Wink
Atilla has:
180 mm Pulley
Cams & valves
80 mm TB
Pistons
5,8 L Engine
Headers
and a realy hot ecu, without CAT-Protection on 75°C CAT
you can find the car on www.mobile.de
Old Dec 13, 2009 | 11:01 PM
Jakpro1's Avatar
Atilla will always be an American hero!!
Wish I could buy that car and import it.
Here is the ad translated from Google Translate
Here is an absolutely unique piece is for sale. My car has the highest stage in the TTP has been installed that runs cleanly and makes everything else going on the road travels deep into the shadows. The engine with the refurbishment is now 9.500km old. The following points were made: new pistons, with increase in displacement to 5.8 liters, bearings renewed Pleullager renewed, 24 hydraulic valve lifters replaced, new timing chain and rail, new piston rings, all seals were obviously re-made, new water pump, other compressor translation, revised to 1.2 bar boost pressure , modified engine electronics, polished valve cover, engine block painted with lettering and covered Plasikverkleidungen in carbon look, Headers, Rennkats (100 Zeller) (before and Nachkats), 2 Water cooling (used for better engine cooling) are used, 2 Intercoolers, and much more. The values are measured at 0-200km / h at 10.5 sec. Otherwise, of course, with DVD Navigation leather etc. Vmax 340
Old Dec 14, 2009 | 12:58 AM
Ali_E55's Avatar
C218 CLS63TT PP Edition1, W213 E63S
i saw the pictures, his engine didnt had SLR intercoolers @@
how is that he had an SLR engine ?
Old Dec 14, 2009 | 02:11 AM
jdj27x's Avatar
SLR sounds so amazing!
Old Dec 14, 2009 | 02:50 AM
fredxxx's Avatar
E55 211
it isn`t a SLR Engine !
The tuner is TTP .
Old Dec 14, 2009 | 02:51 AM
jturkel's Avatar
02 C32 AMG
yes....to both of these....porting increases size.....less boost and less power.....but more flow.....supercharger more efficient now with greater volume
so how do you compensate for losing boost and now a more efficient supercharger? adjust your pulley sizes....and then if/when u go back to your previous boost level, you should see more power at that boost level than you had previously
