Prototype ram air scoops for 63 engine
Old Apr 27, 2008 | 10:05 PM
vegastrashed's Avatar
2007 E63 AMG
Baseline dyno, before installation of ram air scoops
http://www.youtube.com/watch?v=nY4tSMIF5KA
Dyno after fabricating prototype ram air scoops. For those that are familiar with dynos, Dyno Dynamics read very conservative numbers.
http://www.youtube.com/watch?v=15m9bA8Htpk
Picture of the dyno sheet. The red line is the baseline dyno.
Picture of the ram air scoops
Old Apr 27, 2008 | 10:10 PM
BenzoBoi's Avatar
Super Moderator
W221
ghettobird's Avatar
W209
NICE!!!!! Just from the scoops...wow...
Old Apr 28, 2008 | 01:31 AM
jcjmw's Avatar
2005 E55 Wagon
Will the ram air scoops work on a w211 e55? And, how much?
Old Apr 28, 2008 | 01:38 AM
Chargin55's Avatar
2003-E55 2011-C63 2016-C63S
Same question. Can't see why it wouldn't work on a 55. What a simple mod. Good one!
Old Apr 28, 2008 | 08:02 AM
Hazy1's Avatar
'03 E55
To me it seems odd that the scoops would add power when the car is sitting stationary on a dyno. I would think that you would have to be moving to realize any significant gains. I know that you've got fans going, but I wouldn't think that they could replicate real world airflow. Regardless, they look good and should work on the street.
Old Apr 28, 2008 | 08:19 AM
supre55's Avatar
E55
I did something very similiar with my 55, although not nearly as high tech. I took a dremel to the inlet housings right in front of the radiator and opened them up all the way. By doing this you end up losing over 5 square inches of obstruction between both sides. Now I just need to get some python tubes to take full advantage.....
Old Apr 28, 2008 | 08:35 AM
05VENOM's Avatar
old daily driver '07 E63(gone); new dd '14 750xi; 2013 Viper GTS
Is water an issue with this set-up...I drive my 63 everyday rain, snow etc.
Old Apr 28, 2008 | 08:43 AM
Hazy1's Avatar
'03 E55
I did the same modification to my intake as supre55 and have had no problems that I'm aware of. Mine's been like this for probably at least 40k miles now and the only difference is that I find larger insects in fewer pieces in the filter boxes and filters. My car is a DD and unfortunately is frequently driven in rainy conditions.
Old Apr 28, 2008 | 08:59 AM
dc63er's Avatar
junk
whats the net gain
Old Apr 28, 2008 | 09:09 AM
tkracing's Avatar
2003 CL55 stage 4 Renntech and 2006 CLS55 AMG
If you just remove the vent like piece that restricts airflow it should be about the same.
Old Apr 28, 2008 | 11:13 AM
05VENOM's Avatar
Is this the balck plastic piece that can be bent out of the way? WAs told , by dealer nonetheless, that it prevents water and large objects from entering the intake.
Old Apr 28, 2008 | 11:54 AM
tkracing's Avatar
Yes that is the part. Pretty much thats what it is for. I havent done it so cant give much feedback. Just an observation to the ram air concept.
Old Apr 28, 2008 | 12:16 PM
ChicagoX's Avatar
Former Vendor of MBWorld
W211 E55
I have mine in-place and found this in the airbox:
As far as debris goes, I consider that on the large-ish side...
Old Apr 28, 2008 | 12:38 PM
OzE55's Avatar
2003 E55
Well that is what the air filter is for.
I removed those front pieces on my E55 years ago, no problems rain, hail or shine.
I'm sceptical that there is any hp gain, especially on a dyno. How can there be any ram effect without the 'ram' part?
Old Apr 28, 2008 | 12:49 PM
OzE55's Avatar
2003 E55
Sorry forgot the photos.
I packed high temp. insulation foam around the inlet to 'force' air into the intake or through the radiator.
https://mbworld.org/forums/w211-amg/145853-air-tube-temperature-recordings-results.html (its picture number 2, in this thread. For some reason I can't re-upload the same picture)
Old Apr 28, 2008 | 01:40 PM
05VENOM's Avatar
You have to stop driving behind those big 18 wheelers. What else can kick up those size pebbles...er.. stones.
Old Apr 28, 2008 | 01:59 PM
juicee63's Avatar
2011 twin turboed prius
Cool Mod but I agree there will be a better gain when the car is in motion. Your car likely dyno's slightly lower due to thos 20" rims.
I like it , I think it will help alot on the track!
Old Apr 28, 2008 | 02:03 PM
2007 E63 AMG
An attempt was made on the E55 without much luck due to spacing. I'm not sure if scoops for the E55 will be revisited in the future.
Agreed. I was told the same thing. It'll be very noticeable during real world application.
I don't think so, but I'll have to ask to be certain that water won't be a problem.
Originally Posted by dc63er
whats the net gain
10 rwhp. Found out it today that it made more power but for some reason after a dyno it threw some error codes. It has been in dyno mode since Saturday. Can anyone help out?
- CLC0D
- P0300
- P0301
- P0302
- P0303
- P0304
- P0C00
- P1700
- P2116
- P3D00
Old Apr 28, 2008 | 02:04 PM
2007 E63 AMG
Tell me about it! I saw the dyno sheets that Vadim posted with 20" wheels and then the stock wheels on a CLS 63? I think the delta was 20rwhp.
I'm sure you will break into the 11's with these scoops.
Old Apr 28, 2008 | 03:15 PM
ChicagoX's Avatar
W211 E55
- CLC0D
- P0300
- P0301
- P0302
- P0303
- P0304
- P0C00
- P1700
- P2116
- P3D00
Was your ECU disconnected at all during the dyno session?
Old Apr 28, 2008 | 03:26 PM
Vic55's Avatar
Administrator
I have the mod on my M6... clearly the gains are tangible and proveable with that car. Check out the hundreds of posts at M5Board. Eloy at RPI has a fan that mimicks 70 mph driving. My car gained 15 hp and he has countless dynos to prove it with the S85 engine- as for the 63 that is another story.
Old Apr 28, 2008 | 03:29 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
It can be. Drilling holes helps
2007 E63 AMG
Everything was the same as when I left the tuning shop Saturday. This morning, Eloy (operator/owner) got in my car, let it get up to temperature for I think 20 minutes, started a dyno run, and at the end of the run went to get a phone call. Came back to the car and noticed the CEL was on. Confirmed with him that dyno mode was still on.
It's making power on the 63 engine too!
Old Apr 28, 2008 | 03:31 PM
What soft hands you have
Is that running stock that allowed that rock in?
