Drag Radials...
E63 AMG
Drag Radials...
hey all. Was hoping to get some suggestions from you all. I have an 07 e63 with the stock 18" wheels on it. My tire size is 265-35-18
I would like to get a set of 2 drag radials for my car and would like to stay the same size.seems like I can find 275-40-18 bt not in the same sie that is already on that tire. Any suggestions? What are you all doing for rear drag radials? Just want to obviously get the rear 2 so I can switch out when i goto track.
Thanks in advance for your help!
2004 E55 AMG and 2003 C320 4Matic Miss my 993 Turbo above!!
See my sig.......
+2...those were sticky bad boys...I had them on the stock rear rims and made a big difference at the dig. Like you probably already know...just don't get caught in rain and standing water
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
07 BMW X5
Here is the cheapest place I found $215.94ea, anyone found them cheaper?
http://cgi.ebay.com/ebaymotors/275-3...3756.m20.l1116
Will these tires be drag race only? I really liked my BFG d/r's but am gonna try the Mickey Thompson ET street drag radials next.
I have an almost brand new pair of 275/35/18 Toyo R888 tires if anyone is interested in them. It rubs on my car so I need to sell them or get wheels with a different offset
As far as the BFG's, they were good with everyday driving and great for those short digs, but mighty scary in the wet esp. with the hp were are putting out...
I have some of the MT's on the drag wheels (CCW Classics) that I bought off Rflow...I haven't put them on the car yet but if Rflow could break 11s in them I like them a lot! ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
As far as the BFG's, they were good with everyday driving and great for those short digs, but mighty scary in the wet esp. with the hp were are putting out...![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Thanks. I wonder if that tire/wheel combo is lighter than going with a 17 or 18" lightweight wheel with less tire
I know the sidewall on that setup would allow a wrinkle wall but thats when stuff starts breaking
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Question:
If I buy a set up with 18's and BFGs drags on them, will I be able to drive to the track with this? I currently have 20's on my CL and plan on track days putting the 18's in the back. Will this hurt my car? It is a pain to swap them at the track and then figure out where to leave the 20's. Sorry to throw this offtopic, but this has been lingering on my mind.
E63 AMG
Question:
E63 AMG
ok so back to my origional post about this Radial drag thingy.
Since it appears that I cant find a drag radial in my exact tire size which is 265-35-18 and i end up using 275-35 or 40-18 will my times suffer as a result of going to a larger tire? I realize its not much but I would think every little bit counts
Question:
E63 AMG
yeah i was thinking about just buying 2 for the rear and putting them on for the summer. Guess i would be mismatched front to back but as long as I got good dry traction that is fine with me. Just will have to take it slow with the rain.
Use this calculator to determine what will be the best size
Tire Calculator
Looks like your 265/35 has only a minimal tire size difference with the 275/35 thats available for the M/T's
Be warned M/T's are super sticky.. They pick up anything and everything the road has to offer.. Which includes gravel which gets flung back onto your lower bumper with authority.. Also the sticky compound makes for a VERY short life span.. With that being said the M/T's IMO opinion are hands down the baddest Drag Radial on the market!!
Tire Calculator
Since it appears that I cant find a drag radial in my exact tire size which is 265-35-18 and i end up using 275-35 or 40-18 will my times suffer as a result of going to a larger tire? I realize its not much but I would think every little bit counts![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
EBAY Item number: 360048548610
I only see 8 inch wide rims for Kosei T1-S's. Are the 9.5 width inch rims gone?
E63 AMG
Do you all think this will be a problem? Currently the front tires have a profile of 40, the back comes with 35. if I put 40's on the back too is this a problem? What negative affects can I expect if anything?
Darn...Doesn't look like there are any drag radials designed for an 18x8 inch rim...just auto X R compounds. Wonder if they are any good at the strip.
