MJ50's W211 Mod Fever (OEM Retrofits)
Old 08-18-2008, 01:52 PM
  #326
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
holy ****! I want a ride!
Old 08-18-2008, 01:59 PM
  #327
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Originally Posted by BenzoBoi
YOU my friend...are a BEAST!!!
thx sun...
i now can say my car is tad better than stock...
Old 08-18-2008, 02:00 PM
  #328
Super Moderator
MJ50's Avatar
bone stock E55 AMG
mini-meet and u know where
Old 08-18-2008, 02:14 PM
  #329
Super Moderator
BenzoBoi's Avatar
W221
Originally Posted by MJ50
thx sun...
A tad better? Too modest my friend...
Old 08-18-2008, 02:23 PM
  #330
Super Moderator
nlpamg's Avatar
at Pink Taco? ok!
Old 08-18-2008, 02:27 PM
  #331
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
at Pink Taco? ok!
Gotta wait until Franky gets his car back!
Old 08-18-2008, 02:29 PM
  #332
Super Moderator
nlpamg's Avatar
**** that, he can drive the 350!
Old 08-25-2008, 03:55 PM
  #333
Super Moderator
MJ50's Avatar
bone stock E55 AMG
weird engine start
ok... ever since pulley install or ECU tune or both, once every often the car doesn't start like b4...
most times, as soon as i turn the key to start the car, it seems like the whole power is shutting off or something for a split second and then starts the car..
this morning, it sounded like my battery is dead or something...
any ideas???
Old 08-25-2008, 04:25 PM
  #334
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Test the charging system ..load test BOTH batteries
Old 08-25-2008, 04:29 PM
  #335
Super Moderator
MJ50's Avatar
bone stock E55 AMG
how?
Old 08-25-2008, 04:57 PM
  #336
drexappeal's Avatar
how?
Dyno mode!
Old 08-25-2008, 05:06 PM
  #337
Super Moderator
MJ50's Avatar
bone stock E55 AMG
will check later today...
wonder if it's causing my the door control module...
Old 08-25-2008, 05:18 PM
  #338
drexappeal's Avatar
Possibly. Is it still under warranty?
Old 08-25-2008, 05:26 PM
  #339
how?
Go to a Auto Zone and have them check the charging system
1 Alternator output in VOLTS and AMPS
2 Load test BOTH Batteries
a draw/drain will cause a dead battery...this sounds like a weak battery
as if the car had a DEAD battery ..the car will not start
If you want to trace a draw / drain on the battery..that will require a lot more time to trace each circuit for a draw/drain
Old 08-26-2008, 03:42 AM
  #340
Wish4_e55Wagon's Avatar
04 - 06 e55 Wagon - looking for
Can you expand on the euro trunk mod? I'm loving the thinner and wider cutout so to speak. Are you able to fit the standard US plate inside without mounting it in an angle like I have seen on a few euro spec bmw 6 series. What part is replaced? I can't tell by the pics. I would expect this mod can be done on a wagon.
Old 08-26-2008, 10:37 AM
  #341
Super Moderator
MJ50's Avatar
bone stock E55 AMG
i have CPO warranty right now...
will go to dealer to check it out as well as others they need to fix soon...
Old 08-26-2008, 10:39 AM
  #342
Super Moderator
MJ50's Avatar
bone stock E55 AMG
euro trunklid insert has hole for euro plate...
if u just put US plate, then u need to put on those angled bracket to fit...
that's y i put euro plate on first and then US plate over it using zip ties...
euro trunklid insert is the entire bottom piece... u can get it from MBeznNL...
Old 08-26-2008, 11:25 AM
  #343
Super Moderator
MJ50's Avatar
bone stock E55 AMG
alright, here's dyno mode results from this morning...
before car started this morning - 12.3V
after the car started - 14.2V
sounds normal...
Old 08-26-2008, 11:44 AM
  #344
drexappeal's Avatar
sounds normal...
Looks normal to me. Bring it in, MJ. You're under CPO warranty, so diagnostic shouldn't cost anything.
Old 09-03-2008, 07:34 AM
  #345
Former Vendor of MBWorld
MBenzNL's Avatar
some slow@$$diesels
...you should get a 63 IC installed - then you can simply read that kind of stuff from the IC at any given time...
greetingz,
Old 09-03-2008, 08:27 AM
  #346
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
aux trunk locks...
MJ50,
How do the aux trunk locks work? Are they hooked up to the opener/closer or are they separate and require a key to open?
Old 09-03-2008, 10:20 AM
  #347
Super Moderator
MJ50's Avatar
bone stock E55 AMG
greetingz,
lol...
someday steve.... someday...
Old 09-03-2008, 10:21 AM
  #348
Super Moderator
MJ50's Avatar
bone stock E55 AMG
Originally Posted by Yacht Master
MJ50,
all 3 are linked together and work same way as b4...
just 2 more locks to secure the trunk better...
Old 09-04-2008, 11:21 PM
  #349
Super Moderator
MJ50's Avatar
bone stock E55 AMG
McLaren driving shoes
McLaren shop just released driving shoes today...
thx to phil for the info on this...
just ordered low boot shoes today...
no need to buy porsche design or ferrari labeled driving shoes!
Old 09-04-2008, 11:27 PM
  #350
Super Moderator
MJ50's Avatar
bone stock E55 AMG
laced version is also available but i already ordered adidas one...
Quick Reply: MJ50's W211 Mod Fever (OEM Retrofits)
