MJ50's W211 Mod Fever (OEM Retrofits)
#576
Super Moderator
e1000 = lighting guru extraordinaire. Three for three – I’m copying his DIY.
#581
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Here are some resistor solutions (this is gen 1).
http://www.benzworld.org/forums/test...9-99e430s.html
#582
a quarter mile at a time
They look great, I have been lucky with my Rear LEDs on the W211 but not so lucky on the W210. So I have a second mod that will help to make them last much longer. I'll PM it to E1000 to add to his DIY, this weekend.
did you just pop in LED's for your license plates??? That's nuts. nlpamg and I have tried everything under the sun and spend TOO MUCH money trying to find something that works. It's always been that they either blink or eventually burn out in about a month or so.
#584
The way I did it, the LED bulbs fit into the stock housings just above the license plate. You have to take the trunklid lining off to attach resistors so that the LED's don't throw bulb out errors. The resistors that I used are 5w 25ohm resistors.
#591
209/W210 Estate /W211 modded by MBENZNL
Since you will make a video of the NEW feature of the trunk closer
Make a video of the Distronic in motion with the Underline /spacing of the vehicle in front of you...it will show set speed as well
also see IF you can get sound then tail gate a car to set off the beeper/warning
Now only IF we can make the image on the IC change to what it is aka Motorcycle/truck etc
#597
2002 clk430
well, i tried to take pics of the instrument cluster while driving but there was too much vibration...
here's the video of the remote trunk closer module...
http://www.youtube.com/watch?v=R3eDTu5k8_8
That is sick does it close whenever you hit the lock on the keypad?
I contacted mbenznl after seeing your thread the only thing they have for me is the ash tray delete which I think I'm going to get other than that its just the command unit and phone adapter which I have both.
#600
Super Moderator
bone stock E55 AMG
if u press unlock button twice, then it closes the trunk only
