Secondary air pump Troubleshooting
Subscribe
May 13, 2008 | 07:21 PM
I'm trying to fix my cel. Can someone tell me where the relay for this is as well as the valve that needs cleaning? That's what i read when i searched.
Reply 0
May 13, 2008 | 10:48 PM
Quote: I'm trying to fix my cel. Can someone tell me where the relay for this is as well as the valve that needs cleaning? That's what i read when i searched.
unless you have over 80k miles.. this should be covered under emissions
or definately under star mark warranty and manuf warranty.
your car is 2005. You don't have warranty?
My car has gone through 2 different 2nd air pump relays in about 6 months.
Reply 0
May 13, 2008 | 11:46 PM
Here ya go brotha.
Good luck man
N3/10 ME-SFI control unit ......................N10/1IC Circuit 87 engine relay (driver-side SAM control unit with fuse and relay module) ............................N10/1kL Starter relay......................... N10/1kR AIR pump relay
Reply 0
May 14, 2008 | 02:33 PM
What air pump is this that we are talking about?
Reply 0
May 14, 2008 | 03:37 PM
Jakpro, I am not sure if there are 2 relays for the secondary air pump (kinda looks like if you compare MB wiring diagrams and the campaign info for the secondary air pump relays on kompressor engines) but the relay I always replaced for the air pump problem was the one specified by the campaign.
Depending on what your production date/chassis code is the secondary air injection pump relay for the E55 is actually under the fresh air intake for the a/c system by the starter battery, or in the trunk behind the right side trunk liner panel.
Chassis code 803/804 (model year 03'/04') is under the fresh air intake by the starter battery.
Chassis code 805 (model year 05') is behind the right trunk liner panel. It is the relay that is held in with the white clips not the yellow ones.
Replace the relay and the pump. And check the fuse (#61 big orange 40amp in the drivers side front fuse box).
No cleaning of any valves needed on the 112/113 engines, that pretty much only applies to the old 104 (inline 6) engines.
Reply 0
May 14, 2008 | 04:30 PM
Shoot!! Thanks for the info!! I totally forgot he has a 2005. The service I use is for the 2003 E55.
Thanks again!
Reply 0
Jun 10, 2008 | 03:06 PM
Thanks for the help, so the relay is by the starter battery? Which is where?
Sorry, i have an 05' but my gf's is an 03' which is having the issue. How long is the emissions warranty?
Reply 0
Jun 10, 2008 | 11:29 PM
Passenger side or drivers side?
Also where the hell is the secondary air pump? passenger side underneath the car?
Reply 0
Explore
Jun 11, 2008 | 05:35 PM
http://www.autohausaz.com/search/pro...ber=0025421319
I typed in the mb part # 002 542 1319 here for the secondary pump relay & this came up, you think this $6.00 relay will work?????????
Reply 0
Subscribe
Currently Active Users (1)
