Shifter buttons on steering wheel problem
Thanks,
Steve
Thanks,
Steve
One thing irritating me is that it is not possible just to press buttons to engage manual shifting, you always have to switch setting on button to manual. Not very convinient when racing in the higways...
Thanks for the reponse. Are they difficult/expensive to replace? They do seem to work if you press harder a couple times. The car has about 40000 miles on it. I am not sure how much the previous owner used them.
merixus:
I believe on the newer E55 2004+, the buttons are always active when pressed.
merixus:
Unfortunately, you can only get the buttons with the steering wheel so it is a more involved fix then it should be. On that note, the wheel is very easy to replace.
How mechanically and electronically inclined are you?
Steve
THe switch is easy to take apart but contact cleaner will probably not fix it. It is so easy that it is worth a try. When you disassemble the switch, there should be a couple of smalls screws to take it apart. Remove the grey button and set it aside as the contact cleaner can damage the finish on this part.
If this doesn't work and you are mechanically inclined, PM me and I will help further.
Thanks,
Steve
