Another Sirius question?
Is the only way to tell is to take it the dealer and see if it's pre-wired or not? I'm 99.9% positive it's getting installed either way because I hate regular radio. It also seems like I should expect to pay somewhere around 1k for parts and labor if it's pre-wired...sound about right? It's really hard to believe that a car that's going for upper 90k's you have to pay a thousand to have Sirius radio, I guess if people are paying that why not. Thanks in advance for the help.One other question, how much will it cost to have Mercedes incorporate blue-tooth into my command system...500-1000?
BT depends on whether or not you have the phone cradle installed. If you do, just buy the MB BT module and plug it in to the cradle. That's it. 30 second install.
Basically around $1200.00 when it is all said and done.
Hi all, after alot of research, info from the posts and my own trepidation.
I finally decided to install Sat SIRIUS Radio, Voice Recognition & Bluetooth.
Visited MB of Manhattan got a Quote for SAT Radio & Bluetooth of $3800.00 without labor. WHAT??????
so, then decided to go Benzel Bush in NJ, same equipment, quoted $5800.00 Again, WHAT???????????
Anyway, while reading a previous post that mentioned MB Doctor. I Called them up, told them my request and made an appt for them to see my S500.
After 5 min of inspecting my car, the guy told me its doable and I gave my permission.
Out came the SIRIUS SAT Receiver with all harnesses & fiber optic cables, Bluetooth puck MBU2000, used in Porsche & MB in Europe. He even threw in the Voice recognition for free, because i was all up in the installation asking questions, making jokes but keeping a watchful eye. (The drilling of my trunk was a bit hard to take) But, it had to be done.
In 2hrs, i was calling SIRIUS, giving them the ESN for the receiver, 2 min later im up and running with SAT radio, Bluetooth & voice recog using the small lever above the sterring wheel, which my car didnt come with.
A totally enjoyable experience!! And a cost of $2000.00
WHAT ARE THOSE DEALERS TYRING TO DO???????????????? DUH, MAKE MONEY!!!!
OH,
If anyone in the forum is interested in getting it done, I will def recommended this guy to you.
He used to work at MB Manhattan for 12yrs before making his transition to entrepenurship.
PS he also gave me a tip. inside the hood, to the top on the passenger side, there's a black grill. Inside that grill there's a drain hole. He said ALWAYS make sure that hole is free from debris and dirt.
If not, there's a possibility if heavy rainfall occurs, it can cause flooding to take place inside the car reaching as far as where the Nav system is in trunk. Causing MAJOR headaches!!
He's seen it several times.
Thanks for reading
If its saying NO SAT RADIO, it should be wired, just no receiver
