DTM intercooler & SLR intercooler
Question: Does anyone know the dimentions of the IC core?
And what about the dimentions of the DTM one?
Not sure if you can actually buy the DTM cooler separate, I know it just comes with this bypass valve removal piece.
"How do you know this?" you might ask.
I have the same 5500$ piece sitting on my shelf of the garage right now.
Recently just found a real nice guy that works at the local UTA bus garage. Yeah yeah I know, but these guy have LARGE money for high tech equipment and they all work on their race cars under the table at the shop.
We are thinking about using a special cutter they have to separate the cooler from the pipe and having their aluminum welder mate it to a stock pipe with the supercharger bypass valve on it. My tech thinks it won't fit without that special pipe so who knows??
(Supercharger bypass valve) = a smaller version of the throttle body that sits under the supercharger and opens at certain times. To reduce too much boost etc.
Victor & Finny had plans to offer a low cost SLR style cooler I have not followed up on that, but the turbo/supercharger compound induction they have mentioned, will require blower bypass and SLR style intercoolers after the bypass valve.
The SLR coolers are 300% larger than stock.
i remember when this was being discussed a while ago and all i seem to recall were claims similar to yours but i don't think anyone ever showed any proof. again, please correct me if i'm wrong.
Dunno if the ECU trickery to delete the bypass is worth this increase...
Also the frontal area of the cooler is the same, but longer, which means the boost drop off over the core will increase, perhaps that's why there is no bypass valve opening (regardless of the lack of space).
SLR style is the way to go... they sure are pretty and magnitudes more effiicient.
New design with bypass valve came out in mid 2003, so some early 2003 SL55s did not have it.
Stevebez is correct, longer core will add to the air drag thus reducing available boost. I have an E55 in the shop right now that has no-bypass setup on it, I am going to see of we can make it work and what it's worth.
Well it's official, I really do have a 5500$ trophy on my shelf.
Well unless Vadim can get er to work with the bypass.....then heh heh heh.
if vadim can get the tuning right and is able to shut off Bypass valve, I'd say install it!
For the ultimate 55, TT is the way to go and use all the space occupied by the blower and I/C for one massive top mount... and go large on the H/E and pump.
Use the area where the primary cats are for the turbo's and you are set....
Better intercooling and more efficient boost. Minimum +100hp pick up when pumping the same boost as before.....
