Check your VRP Pulleys, Please
#76
Former Vendor of MBWorld
W211 E55
It was the delay in any reply, followed by the broken promises, that dragged out the schedule. CPT and LET stayed late (after 11pm) on the two nights leading up to the event, wrenching on and tuning my car for the new pulley. We simply ran out of time.
LET offered to have a one-off pulley made for me, but I declined. Their near-heroic efforts in tuning my car was enough for me. After Erick informed me that ASP had one, I bought it.
VRP failed to supply original torque specs for the outer ring bolts, and it took two days for a reply on that. Add three weeks of stonewalling after the issue was disclosed, and you get me missing my event. Somewhere towards the end of that, I got fed up and ordered the ASP.
To besmirch my honesty and character with your above post shows me that you're no better than the other nut-swingers. What compensation did YOU receive for the merciless thrashing of your car by VRP? Free parts? Money?
I've been nothing but honest in my characterization of the situation.
For those who can count, that's more installs than VRP pulleys EXIST.
Good luck with your TT project, Jangy.
#77
2015 S212
After Erick informed me that ASP had one, I bought it. VRP failed to supply original torque specs for the outer ring bolts, and it took two days for a reply on that. Add three weeks of stonewalling after the issue was disclosed, and you get me missing my event. Somewhere towards the end of that, I got fed up and ordered the ASP.
Got it. i didn't realize you decided on the ASP later.
Wayne..... I am not questioning your honesty or even that of your tuner. I simply asked the questions that are out there and you replied. We (general public) did not know the details. That is it. I thought I had read you say earlier that you just wanted the VRP off and an ASP on so I wondered why you would miss the event. That's it. We didn't know. Just because I ask doesn't mean I think you are a liar or deserve to have this happen.
Rather than blind faith, I have 30+ crank pulley installs as evidence of 'skillz'
Again, I am not questioning your tuner or installer's abilities. I am simply saying that if we are going to be objective and not make assumtions (as I had with assuming that a pulley manufacturer would use a proper grade metal) then the same should go with our deliverance of the install. Again, why blind faith? I really think the only odd thing is the black goonk and where it came from.
So, just to be clear....No money from VRP, barely a discount, and no other special treatment. So, why did I allow my car to go through that? OK, here is the deal. As I said, I trully trust Vadim with tuning. He knows me well and knows what I expect out of my car and from my tuner. Because he has always gone the extra mile for me, I am willing to let him "use" my car.
Sorry for the OT here. I never meant to divert your progress so i will not post in this thread unless it relates directly to the topic. We all have our loyalties and allegiances and honestly, I like the fact that you guys have a strong relationship with your tuner and expect no less than for you to stand up for them. Just don't be surprised when someone else does it for theirs.
#78
'10 Porsche Turbo PDK, 500e, GL450
#82
I wonder if the wobble is wearing the supercharger belt as it would be more pronounced there due to the larger diameter as well as being the furthest away from the mounting.
Having it checked by Sunil isn't a good option as Houston is a 3 1/2 hour drive one way just to have it looked at.
#84
hey chicago
i feel your pain BELIEVE ME. but what does the outer ring bolts specs have to do with the keyway damage?
but if your crank is fine and there is no damage to the keyway on the crank YOU HAVE NOTHING TO WORRY ABOUT...
vic didnt send you a new pulley which you say you didnt want anyway so again your good. BUT THEY GAVE YOUR MONEY BACK. or most of it like you said. im sure youll get the rest if that is the case.
so if all this is the case you are back to square 1 like it never happened while only being inconvienced which is the risk we all take when we mod our cars...
i can hear the frustration through your posts bro.
#85
'06 E55, '05 SLK55, a few others
Like the assumption you made here:
Please don't take this the wrong way as I am not trying to be a jerk. I simply think that your logic needs to be questioned. Being a Kleeman dealer and having done numerous other pulley installs does not make the installer exempt from making small mistakes. And as you know, even the smallest mistake with a crank pulley can have exponentially greater effects at redline and high revs.
There are lots of the pulleys floating around and plenty of users that have not had problems. To me that means they have been designed and engineered by someone who knows what they are doing. The same cannot be said for every installer. Not to mention the bolts were "thrown away". I find that odd and suspicious....especially considering the reason for the pulley removal/inspection and being sent back etc.
One question.....are these pulleys sent to installers/retailers WITH bolts ?? If so, the bolts should have been saved after removal for inspection.
1. The pulley is defective.
2. The installation was incorrectly performed.
The third possibility is not being considered, and that is, the design is flawed. The fact that many of these are in service and working correctly precludes the third possibility. I think that if the dimensions of the pulley are correct in all respects (obviously excluding the damaged area), the only other causal factory for a defective pulley is that the material used is not of the correct strength/hardness.
Vadim/Victor, do you intend to make a thorough dimensional AND material analysis of the pulley? If it passes these tests, I think there is nothing else to assume except that the installation is at fault. Would anyone disagree with that?
I ask these questions to determine what exactly happened, not blame anyone involved. My reasoning is that like others have stated, I don't believe that there are zero "wobblers" out there, even on stock pulleys. I'm running the Kleemann pulley that was installed by Evo, and guess what, it wobbles. It's not very noticeable, but it's there, and the K pulley is based on a stock MB center with a larger out ring ala ASP, but pinned rather than welded. It's been on the car for 7K+ miles and I've never heard a squeel or replaced the belt, but not having seen the stock pulley running on the car, I wonder if it did or did not wobble?? Is it possible that the tolerances of the original pulley are not as exact as they should be? If the stock dimensions of the pulley bore and keyway aren't "perfect", does this mean that fully aftermarket designs that use these dimensions are also then flawed and possibility #3 is the root cause of this??
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
#86
I have a headache now.
BTW just because someone has done an install 30 times does not mean no mistakes can be make. I'd be really curious if the installer did both pulleys around the same time or if he had done any pulleys inbetween?
#87
W211 E55
I'm glad someone else is thinking about "option 3" as well.
dc63er: During the install of the VRP pulley, it must be disassembled to be installed with the provided tool. The outer ring bolts on with secondary hardware, and the torque specs weren't provided initially. It took another two days of sitting in the bay before a response was received. Both LET and CPT were subsequently called out for potentially not torquing the bolts down, even though LET had nothing to do with the install. The litany of finger-pointing that followed is what truly let me down as a customer.
I am frustrated, yes. I also don't want anyone else to enjoy the same issues.
#89
E55
I think the real question here is not if a stock pulley wobbles at all or if your Kleemann Pulley wobbles at all but if either the stock pulley or the kleemann pulley have been damaged. Since they wobble does that mean that they have similar damage as the VRP ones seen in the photo above?
BTW just because someone has done an install 30 times does not mean no mistakes can be make. I'd be really curious if the installer did both pulleys around the same time or if he had done any pulleys inbetween?[/QUOTE]
Awhile back ago i had found out that my Kleeman pulley was wobbling and it got me worried..so we removed the pulley and found the exact same notch where the key is supposed to slide in..it looked like a mis-install but what was surprising was that my stock pulley had the same notch
my car has approximately 78,xxxx miles and i have no belt shreading, noise, no leaks or unusual noises coming from the bottom of the block or anything for the past 50,xxx plus miles. So im guessing that some of these cars come with the wobble from factory...maybe a few
#90
W211 E55
A week later, LET (not me) was informed that the holdback was due to the install tool not being returned. Since it's at the shop, I told them to send it back with the other failed pulley. Now, I hear that they don't want the pulley back, so I'm in limbo. I guess I need to drive to Melrose Park, Illinois from Michigan, get the $15 tool, ship it back to VRP at my expense, then patiently wait for the rest of the funds.
Whatever. My time is worth a bit more than the remainder of the refund - it just is further evidence of how this deal was handled.
#91
Also when I first noticed the belt squeal I emailed Victor directly and the first thing he suggested was to check the outer bolts. He replied with the torque specs within about 30 min of my initial email. That was over a month ago. No problem with the bolts were found though.
#92
[/B][/B]
my car has approximately 78,xxxx miles and i have no belt shreading, noise, no leaks or unusual noises coming from the bottom of the block or anything for the past 50,xxx plus miles. So im guessing that some of these cars come with the wobble from factory...maybe a few[/QUOTE]
I looked, and there is zero damage to the stock pulley. The keyway and bore look perfect, but again, I never saw it running on the car. I did look at the Kleemann pulley again, and it's only a slight wobble and I don't know how it could be possible, but if anything it's maybe slightly less noticeable than it was immediately after the install. I wonder if anyone has ever actually put a micrometer to the crank snout and/or keyway to see how that compares to the measurements of the factory pulley????
#93
W211 E55
Hmmm, I don't understand why they would have taken the pulley apart to install it. I watched Sunil install mine and he did not have to take the bolts out to put it in. Why did they say they needed to dismantle it to install it?
If they didn't want the pulley dismantled, they shouldn't have shipped a tool that requires dismantling of the pulley for use.
#94
#95
#96
E55
I contacted Kleeman but since it was over the 1 year warranty they said there's nothing they can do for me. The pulley was not damaged as i thought it was. I put on another stock pulley(not mine) and it was wobbling. So i just put back the Kleeman pulley back on with the new crank bolt. Still wobbles....but not worried
#97
2003 E55 AMG
Wayne,
I want to add a few more facts here because I see that alot of misinformation is being posted now.
When the problem was reported, Erick from LET called Vadim. He told Vadim about the problem. Vadim right away asked for 1) Pictures 2) The original Crank Bolt. NO ONE sent anything.. no pics, no bolt, nothing. When Vadim told Erick this he basically waited until the information came back to take action.
What did you guys expect him or me, or us to do? We got nothing but a verbal on the phone saying the pulley was bad and that the "Customer wants his money back"..
Dont you think its fair that we get the information we asked for so we can review it and determine what happened?
So, the delay of 2 weeks or whatever it was before you actually called and spoke to me directly was not our fault. As far as Vadim knew, he was waiting on you guys to send the info back.. I didnt have the details of what was going on because Erick was dealing with Vadim directly.
Once you called me directly and we spoke, I took action immediately, sending out the refund still without seeing a picture or getting the pulley back or having the original bolt.
Now that I have the pulley back, its my belief that it was damaged during install. There is nothing wrong with the way the pulley is manufactured.
Chris @ C2 Designs installed these, Vadim installed them , Sunil @ Motorwerks installed them, Satish @ Motorwerks in Detroit installed them and there are a bunch of other people (MB Techs and dealers) that have installed these pullies without fail.. NO ONE has had this problem.
Again, more misinformation... Who is telling you this stuff?
I refunded LET 100% of THEIR PURCHASE PRICE OF THE PULLEY. The pulley is what was sent back and that is what I refunded. In fact the Dealer price of the pulley included the installation tool, which i never received, but they were still refunded for it.
They bought 5 pullies at the same time. On their original invoice they were charged SHIPPPING. When Jerry looked at the bottom line figure on the invoice he took the whole thing and divided by 5 to get a single unit price which is not accurate because that took into account the shipping and waterpump. MAKE SENSE NOW?
Bottom line is, they were not refunded $50 worth because I thought you KEPT the Waterpump pulley.
On top of all this, LET is the original vendor who sold you the pulley, so if you were so upset about it, and you, LET and CPT were so sure it was a bad pulley, why didnt you just get your refund directly from LET and let them deal with me on their own time??
LET was NOT WILLING TO give you anything back unless I first gave them a refund for their purchase so the only reason you got back what you did was because I forwarded them their refund before I even received anything from you guys.
And for that I get these bitter posts and misinformation being spread.
How many vendors have you dealt with that refund money on product sight unseen with just a verbal word that the product is bad? Especially on something like a crank pulley where most of the time its an installation issue.
A few things need to be cleared up:
1) There was never any paint, polish, or other substance put on the pulley after removal. It came off my car, went in a box, was shipped to VRP. Any other suggestion is insulting, untruthful, and an attempt at misdirection.
2) My bolt was not saved, as I was not interested in doing a forensic analysis on this at the time. I wanted that pulley off my car and the ASP on as quickly as possible, since my track rental was imminent. As it ended up, my car missed the event I organized.
3) I WAS STONEWALLED FOR THREE WEEKS. It was only after I contacted Victor and Vadim directly that there was ANY movement on this.
4) VRP took no responsibility, initially. Per our telephone conversations and e-mails, everyone was blamed for potentially mis-handling, mis-installing, or generally fudging up the whole thing, except VRP.
5) I offered to both take pictures and send the pulley back - without a refund. Victor then said that he would refund me anyway to get this deal closed, as it had BEEN THREE WEEKS already. He then contacted me a half-day later, stating that I needed to seek a refund from LET, since they sold me the pulley, and he would only issue them a refund after part analysis.
6) At this point, I took a defensive position. I would return the pulley after proof of refund for a defective, unwanted product was underway.
No.
#98
2003 E55 AMG
Marcus,
You've always been considered a friend in my eyes also, and I am sorry you had to go through this.
I think you know my personality pretty good now from dealing and talking to me over these years.
You know that if I truly believed the pulley was bad or there was an issue, I would admit it, put the tail between my legs and apologize for the problems and inconvenience...
I truly feel there was a mistake made during install.
I truly feel that something happened and someone tried to cover up the damage with a black paint/substance.
Everyone can have a bad day.. If a shop has installed 30, 40, 50 or 100 pullies, it doesnt mean someone can't make a mistake. We are all human.
The shop being CPT is even more delicate for me because I've never heard a bad thing about them. I know you guys have all had great things to say about CPT and I agree that they are a good shop, but, it doesnt mean the tech doing the install couldn't have made a mistake, got scared and didnt want to admit to everyone that he screwed up.
You really can honestly look at those pictures and say that the hardened steel snout on the back of the pulley was damaged during the torque procedure?? I just dont see that happening.
There would be a concave structure formed on the frontside or backside of the pulley if it was warped during torque. There is ZERO damage to the face or rear of the pulley.
The only way the keyway could get chewed up like that is if the key is not fully inserted and the bolt was torqued down.
#99
2003 E55 AMG
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Also, I would like to point out, if you buy a product at Walmart and are unhappy with it, you take it back and get refunded from the place you bought it from, not hunt down the actual manufacturer (hell, which would probably be in China from my example...LOL!). While I think the question about the pulley integrity/install is still being debated, I would like to say LET's customer service should be questioned as they didn't pony up a refund immediately and simply deal with VRP. Or maybe, we are all just so in touch with each other that the lines get blurred.
#100
When Sunil did mine he removed a plate on what I believed was the transmission(don't hold me to that). By screwing in a bolt or something he was able to prevent the crank from spinning and installed the pulley with ease. Nothing was attached to the pulley and no dismantling necessary. I watched the whole thing.
