Command - Change logo to AMG
Old 06-23-2008, 04:36 PM
III II I I AMG's Avatar
2003 e55
Originally Posted by BigApe
I must be the only tard here... All I managed to do was to set my #3,5 and 7 presets to the same station.
dont feel bad, me too... its pissing me off that i dont know what is my command.. which feature is that? and how do i go to my command? and what do u guys mean by going to the radio? like, turning it on? or set it to fm, or am, or what?!?!?! so aggravating, any help is greatly appreciated
Old 06-23-2008, 05:14 PM
psk145's Avatar
2006 E55
command is the radio. Set it to FM, and then try the 5,3,7. Worked for me after a few tries.
Old 12-17-2008, 03:27 PM
kip
kip's Avatar
E55
Originally Posted by por997s
Hi Guys,
A tip from a good friend of mine. Works a treat! I am sure most of you already know this, for those of you who dont here goes.
When you first start you E55 up, the COMAND system displays the 'STAR symbol. Well if you'd prefer to see the 'AMG' logo instead, then just do the following:
Turn ignition key to position 1 or 2.
2. Turn on Command.
3. Turn to Radio.
4. Press 5 (continue holding and wait 1 second).
5. Press 3 (continue to hold along with 5 key and wait 1 second).
6. Press 7 (continue to hold along with 5 and 3 keys and wait about 3 seconds).
7. A menu should appear. Scroll down and select "AMG211_ECE" option.
8. Switch off ignition, remove key and leave about 5 minutes before turning on again
This is really nice and it works. There is a big variety of possibilities. Anybody know what the other AMG etc logos look like, and do they work?
Old 12-17-2008, 04:11 PM
E55_GT3wheels's Avatar
2010 E63, 2008 Range Rover Sport, 2010 GLK350
it does work. I did this a couple months back. It took me a while. I also set presets 3, 5 and 7 all to the same station many times. After 20 minutes, I finally got it. Not sure what I did different but keep trying. It works!
VERY VERY short lived though on startup. I wish it stayed for 10 seconds or so (not half a millisecond). The original mercedes sign stayed up longer.
Old 12-17-2008, 11:30 PM
E55-0817's Avatar
2004 E55
Hi Guys,
2. Turn on Command.
3. Turn to Radio.
Will this work for an 02 CL55?
It worked on my W211 E55 when I tried it out yesterday. But so far, there is no luck with the CL55.
Old 12-18-2008, 01:41 AM
NSX2NV's Avatar
03' E55 Techtite Grey
Good tip! I'll try this tomorrow.
Old 12-18-2008, 02:57 AM
  #32
kip
kip's Avatar
E55
Anyone get the other signs to work? I agree, it stays on for a very short time!
Old 12-18-2008, 12:56 PM
  #33
Super Moderator
MJ50's Avatar
bone stock E55 AMG
02 CL55 uses D2B so prolly that's why...
Old 12-18-2008, 05:03 PM
  #34
E55-0817's Avatar
2004 E55
Cool
What is D2B?
Old 12-18-2008, 06:45 PM
  #35
liquiddi's Avatar
2009 E63 AMG
still doesn't work on a 09 E63.
Old 12-19-2008, 03:40 PM
  #36
Vivo's Avatar
2007 E63 AMG, 2009 V-Max
It worked on my 07.
Old 12-22-2008, 11:49 PM
  #37
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
So upsetting! This didn't work on my 03 CL55
Old 01-13-2009, 03:45 PM
  #38
NSX2NV's Avatar
I've tried this several times but it hasn't worked. Is it because I don't have navigation in my 03"? I have the radio that has the smaller screen and a tape player. The screen does show the Star and say Mercedes Benz on startup. Anyone know what's up?
Old 01-13-2009, 03:54 PM
  #39
cneedham810's Avatar
01' E Fifty Five
Hey guys, any such luck on an 01' E55?
Old 02-16-2009, 11:57 PM
  #40
JBFMCAR's Avatar
G63, 360CS, CLK63 BS, 997.2TT, 328D
Good info to know about to install a command screen.
Justin
Old 04-29-2009, 07:18 AM
  #41
intellilogic's Avatar
'12 E350 Coupe (3rd Benz)
This works on my 08 - I need to redo it, had the unit replaced (yes, the entire unit $$$, long pointless story) I think it was slightly different, the way I did it, I don't remember for sure, I will go and try it soon and let you know.
Old 04-29-2009, 07:33 AM
  #42
Wink
63 & keyless: (55's read too, so you don't save stations)
Ok, I sit in the car, hit the keyless (or you can turn key) without starting the car - I think it works just the same if you start it, but I didn't test it.
I go right from the map for nav, this is kinda tied to the radio if you press those buttons, but mine was playing from the CD Changer. I am pretty sure you can actually do it from anywhere in the command system.
I press 5 (1sec) 3(1sec) 7(wait about 5 full Mississippi) (Middle, Top Right, Bottom Left - I have seen people do 7,5,3 and get confused)
Then you come to the menu, mine also offers me AMG 171 and some other options on there, like 6, haha.
Select either 171 and 211, I played with this before, its the same damn thing. Turn car off, if you have keyless, open the door.
Now this is the annoying part, it takes like 15+ full seconds before you can do anything or it won't work. If you try short of that, you will get the benz logo.
Old 05-01-2009, 07:44 PM
  #43
BlackBeast'06's Avatar
'06 cls 55 amg, '03 Range Rover HSE, 88 Firebird Formula
Worked for me like a charm. Didn't encounter any issues on my '06 CLS 55. Thanks a bunch.
Old 05-01-2009, 09:35 PM
  #44
LADY_AMG's Avatar
E63 AMG & CLK350
Hmm...strange. These instruction worked on my E63, but not the CLS63. I tried 3 times on the CLS. Maybe I'll give it one more go.
Old 05-01-2009, 10:59 PM
  #45
JDM Joe's Avatar
08 350Z, 09 E63
Does anyone know if this works with the newer COMAND in the 09 E63? It doesn't seem to work for me..
Old 05-10-2009, 02:55 AM
  #46
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
THANX WERKED KILLER, WOKE UP MY GF doing it tonight I did not lose any AM stations or anything
Old 10-14-2009, 10:43 AM
  #47
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
So this worked on your 07 E63/. I haven't gotten it to work on my 07 E63 yet, I guess i will have to keep trying. I went to my local MB dealer, they couldn't get it to work either, and I talked to several techs about it, no luck.
Old 10-14-2009, 11:04 AM
  #48
myntk12's Avatar
2004 E55 AMG
Works great. Should have been this way from the factory.
Old 10-25-2009, 10:23 AM
  #49
swadhwani's Avatar
2009 E63 AMG
I too have an 09 E63 and cant get it to work...the 09's have the newer Comand.
Old 10-26-2009, 07:57 AM
  #50
£ C43 £ AMG £'s Avatar
E55K AMG
I have an APS 50 Sat Nav, but no NAV DISC.
It shows the Mercedes Star on start up, do I need the NAV disc to change the logo?
Quick Reply: Command - Change logo to AMG
