ECU tune w/o other mods?
1 Post
germans
Anybody get an ECU tune on a stock car? I'm wondering if there would be a noticable difference if I went that route.
Don't want to go mod crazy because Hawaii only has 1 dealership here, so if they blackflag me for modding, I'd be screwed big time.
I too dont plan to go too nuts modding my ride.
I did the resonator delete and the the Renntech ECU tune and ELM. Yes I did see noticeable gains from the ECU tune. It is mostly noticeable in the first 4 gears. they are a little more responsive and seem to give me just a little more mmmppphhh in each lower gear. ECU tune also changed my top speed from the stock 155 to 187.5 mph
Only plan on really doing a few more mods. Got the VRP CF airbox coming in some day....not sure what else im gonna do but for now thats probably about it...
I see you have a 55k, not sure if ECU will help much with those, on the 63's its seems to make a difference
1 Post
05 E55t, 07 R63, 04 Mini R53 (SOLD):01 s4 avant st3, 06 q7
I have used Veloce ECU and dyno before and after. it only bump a few hp more.
but the the main different was the responses. it was really fun driving with it..
that was on a 55 stock car.
ECU tuning on the AMG cars is hit and miss and sometimes gaining something takes away from something else. Good luck it would be worth a try, if you are not happy get a refund immediately
2015 S212
A tune without other mods can really just focus on tightening the tolerances to get better power. Things like octane setting, leaning out, moving the speed limiter, moving the rev limiter, etc. is all you can get. In all honesty, I wouldn't do it.
Instead, find a way into your dealership. Once you are connected, you can do whatever you want.
If you don't want to go mod crazy, then you might want to consider:
1. Stickier tires...I've tried BFG's and Nitto's drag radials. My personal opinion is that the BFG's are better for traction, but the Nitto's are better for day to day. I was worried about the driving in the rain, but the Nitto's were a lot better than I thought...the caveat...just as long as you don't go crazy on the throttle.
2. Lighter wheels from stock (unsprung weight reduction)
3. Lighter rotors (unsprung weight reduction)
4. Upgrade your IC pump.
5. Sprintbooster (no real performance increase but perception of quicker throttle response is boosted)
6. Upgrade your brake pads (increased stopping performance and less brake dust)
Like Jangy said, I think an ECU tune without engine mods would be wasting your money.
06 e55 wagon
My understanding is that it's worth 20HP/20TQ on a stock car. Which is not that much given 500HP/500+TQ stock. However, due to timing increase the car might feel more responsive and due to leaning out a bit you might actually get better gas mileage if you can stay out of it. As mentioned you also get speed limiter removal and rev limit increase if you want. Given that, it may or may not be worth it to you based on the cost.
Well I chose to go ahead with the ECU tune. Yes its only a little bit of additional gains, but i was given a price I couldnt turn down. I agreed not to disclose the price per my agreement with Renntech, but can say it was VERY significant with what they typically charge for a tune.
Thats why I went that route. And personally I dont regret it one bit. Car feels they way it should have out of the factory with what was done.
GL with your decision.
2015 S212
