*** Bad Crank Pulley Installs ***
There was a thread that was started a few weeks ago where we were discussing whether or not a VRP pulley suffered damage either from an improper install or because it was defective.
The reason I am making this post is because one of the members on this board had the same damage occur to his STOCK E55 Crankshaft pulley. Whoever installed his stock pulley did not follow the proper procedure and it resulted in keyway damage.
Below are 2 photos showing the damage to the keyway on his stock pulley.
Notice how the damage is almost identical to what happened to the VRP pulley that was discussed here: https://mbworld.org/forums/showpost....1&postcount=45
If the bolt is not torqued down properly, the pulley will wobble, and the back 0.75" or so of the keyway will get damaged as shown in both sets of these photos.
Wonder how many would come back with no bolts!!!!
Sorry, I had to
Anyway, I'm sure when this happened you had a nice sight of relief....not to worry - I for one never doubted your product.
Perhaps to strengthen your case even further you should intentionally install a pulley the wrong way and then take photos after it runs for a bit. Something tells me the photos would look almost identical to the above.
Pleased that Vadim and his consummate technicians installed its crank pulley, however.
DING DING DING !!!! I think one of the reasons that many of us are here is because we are so meticulous about our vehicles...that's why many of us do our own wrenching because we know it gets done, to a T as you said. More often than not when someone else works on your car, that is not always the case and procedures are overlooked and corners are cut. The photos don't lie and it's really too bad because the smallest mistakes can have catastrophic results. Especially when you are dealing with something as highly engineered as an AMG motor.
I have full confidence in your proucts and have nothing but praise for you gentlemen. I hope this helps settle that the Pulley must me installed correctly or there will be damage. I hope others take notice of this thread and learn from their mistakes on installing the pulley.
I have not had any issues with my car but does that mean that everything is OK?
I actually think the pulley gets the dent when the bolt is torqued down when the pulley holder tool is not used correctly, or more than likely when the tranny lock method is used. Using the tranny lock method is - to me - looking for trouble. The torquing and stresses are completely different when the pulley is held fixed with the tool than when the crank is being held fixed, with the torquing plane very offset from the locking plane. With the pulley tool they are as close as could be in one plane.
I think with the tranny method the pulley bolt begins to grab on the pulley when being torqued, the pulley twists on the crank snout and then damages the keyway....
I can't see why one would risk doing it like this.We all know what benz say.... why would they have a special tool if they could just lock the tranny up using a bolt??
So that pulley damage looks like faulty install caused during torquing to me....
the squeak is loud upon start up with the VRP pulley wrap and i am getting a new idler pulley to replace for a start. still trying to isolate the correct squeak maker.
I think it was obvious to everybody what was going on in the other thread, especially after it came out that you had requested the bolt but instead it got "thrown away".
my first gen. pulley also had a wobble. After sending a second pulley, that one wobbled, so Ken got me a new dampened pulley, and it also wobbles.
So I guess its safe to say that a slight wobble should be OK.
1) Check material hardness for accuracy.
2) Put a dial indicator on the pulley and check for variance between factory and aftermarket wobble.
I'm sure there are few other things that can be done that I may not be aware of but a machinist/engineer knows.
Something smells very fishy here. It's not VRP, and it's not CPT... something is smelling awfully fishy from Germany. I am seeing MORE and MORE evidence of pulleys from MB that have never been touched/modified wobbling/damanged. We have now a picture of a never re-installed pulley (that wouldn't be subject to install/torque errors) having keyway damage. Now, I, like everyone, want to believe this hand-built business is great and AMG is the best engine builder out there - but I have seen some very f'd up things from OEM manufacturers before - and I think at the very least we need to start looking into the AMG/Factory side of things a bit more closely.
The plot thickens.
-m
my stock pulley also had damage to the keyway when it was removed. i personally don't think it's an installation problem but more of a problem when the s/c kicks in and causes a large and abrupt tq spike against the crank pulley. this could be another reason why mb designed the new s/c clutch to engage smoother (you know they wouldn't do it just for our comfort).
It may not be a big deal when there's a slight wobble, but that slight wobble can be exasterbated by larger pullies and multiple installs. A wobbling crank pulley, I think you will agree, is not a good thing. A slight wobble may not be the end of the world, but I've seen some pretty significant wobbles.
We may need to look at things from a whole new angle - meaning part of installation may require observing stock wobble, checking the stock key/keyway, and make adjustments as necessary, because it could be what you are saying or it could be some of these engine builders in Germany may be cutting corners
-m
