Pheno Spacers w/ CF Box
I was concerned b/c there was information posted that the c/f airboxes may or may not work as a result of surge tanks/intake manifolds sitting higher due to the increased spacer thickness. The RT box uses the OE box lower portion, so I simply removed the rubber grommits and it fit like a champ.
I also took the time to clean the tb and the rest of the compartment, re-painted the tanks/manifolds, and wrapped the intake tubes. Friday I head to Chris at Floored Fab to install a new FMIC w/split circuit. I will post data log results after w/ IAT's.
If there's something I'm not seeing here please inform me as I've always been curious about this.
So, I would also think that separating that surface area of the surge tanks would allow the other areas that I had mentioned to heat soak even faster.
And, seeing that the last place that the air passes through is the short runners below the surge tanks and the cylinder heads themselves, wouldn't this render the spacers innefective, if not counter-productive?
Thus air out of intercooler ends up cooling surge tanks. When spacers are installed the surge tanks end up around 120-130F, very close to IAT.
As far as extra heat, it get taken care of cooling system, which has a lot of reserve capacity.
New HE and pump w/ split circuit go in tomorrow. Plenty of WOT runs planned for tomorrow and will report the numbers.
