Smaller S/C pulley boost question
Old Jul 29, 2008 | 10:58 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
I have a Kleemann Eaton root style S/C with a 2.8" stock pulley that make 6.2 psi of boost on a cool day. If i put in a lighter (half the weight) 2.6" pulley, how many psi should I be making?
thanks
Old Jul 29, 2008 | 11:03 AM
jangy's Avatar
2015 S212
I dunno, but I'd bet the drag of that extra weight would make a difference. Is the pulley easy to come by? DOOOOO EEEEEEETTTTTTT!
Old Jul 29, 2008 | 11:51 AM
I had a machine shop CNC a 2.6" out of aircraft light weight aluminum for me but I have to buy 5 in order for them to turn on the equipment So I have 4 extra if you know anyone who want to buy it off of me. I can't believe how heavy the stock pulley was.
anyway, i had it installed last night. but i only seeing a 2 psi increase on my boost gauge. I hear other saying a 65mm will make 12psi, I don't know if this depend on the car or is there somthing wrong with my S/C
Old Jul 29, 2008 | 02:45 PM
blackbenzz's Avatar
haters crazy
Where are you reading boost? Pre intercoolers?
Old Jul 29, 2008 | 06:16 PM
I T it off at the manifold.
Smaller S/C pulley boost question-dsc01148.jpg
Old Jul 29, 2008 | 11:48 PM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
That's right. My 65mm made 12psi. I still have it since you returned it to me. I had another one made 70mm and it made 8.5psi and that's what is on my car now.
Old Jul 30, 2008 | 01:24 AM
This suck! Kleemann really screwed buyer who have the Eaton root style S/C.
Btw, this is the pulley off my S/C.
Smaller S/C pulley boost question-2.8-pulley.jpg
Smaller S/C pulley boost question-2.8.jpg
Smaller S/C pulley boost question-2.8pulley.jpg
Old Jul 30, 2008 | 12:35 PM
AMGSC's Avatar
Your 2.6in pulley makes 8psi vs. mine which makes 12psi is due to the roots vs. twin-screw design.
The good part about your SC kit is it makes instant power in the lower RPMs, easier and cheaper to repair and less likely to break since the lobes/rotors tolerances are not so tight. If my SC breaks, it would be much more difficult to service than yours.
Old Jul 31, 2008 | 08:49 PM
PTE's Avatar
PTE
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Blower pulleys
Peter : Here is the guy I go to for pulley's & he stocks them. The outher issue with using a small Diameter pulley , is that you lose belt wrap. and Belt slip % may increase http://www.southfloridapulleyhq.com/...ed_pulleys.htm Cheers _PTEngineering
