3 wire or 4 wire sensors for Airmatic
I wired my ELM initially for 4 wires per the directions. All the wires were there to use, and the ELM worked fine. The problem was when I turned it off, the car would lift on the drivers side, but not the passenger.
So after talking to some people, I wired it for 3 wires, and it also works fine when its on. But when its off, same deal. Raises on the drivers side only.
So who is right?????
I called jangy yesterday to get his take, but I figured Id get the rest of your opinions on this
I got one of the first Gen 2 modules, so Im thinking maybe the module is defective?
ALL W211s with Airmatic have a single sensor in the rear and it is right above the pumpkin, and two sensors in the front. What is the 4th wire to? Are you saying that there are 4 sensors, because the module has many wires.
Also, I have not played with the V2 nor scrutinized the instructions like I have the V1.
From all the trouleshooting we did, I would at a minimum take the module off and make sure the car ride is good to go. You never know if you have a short or even a tweaked ride height calibration from the module install? Find out EXACTLY how the diagramming works and then start fresh. all things considered, I'd ask RT for a new one but don't hold your breath. Group5 has the remote, wired of course, if you are reinstalling anyways.
if you look on page 8 of this pdf
http://www.renntechmercedes.com/support_files/mb_lm.pdf
my car has wires 21, 36 and 34 present in the stock harness. So because of that, RT says car is to be wired for the 4-wire setup. It looks like there are still maybe 3 sensors, but 2 wires from the rear.
Hmmm, I don't get the pdf.....
Told you to get the V1 for cheap.
There are 2 wires available for the rear, and 4 for the front assuming a 4-wire sensor install. Then there's the CAN wires, which I dont know what they do.
I used 1 for the rear and 2 for the front, wiring it as a 3-wire as I was told here.
I got the V2 for the same price as the original.
Bro, that's only three sensors. each has 2 wires to loop it. You have 4 for the front, right? And 2 for the rear. That is 3 sensors.
Hasn't anyone else installed a V2 into a newer E? My V1 only has 8 wires on it, so its easy to figure out. How many wires are coming from the V2?
I was told here that it was incorrect
https://mbworld.org/forums/w211-amg/249736-renntech-elm-users-please-share-your-long-term-reviews.html
I didnt use a pin removal tool, I just used something I found with a small point to press in the tabs.
The V1 was that way, too. I guess we need to translate renntech speak to laid men's terms
https://mbworld.org/forums/showthread.php?t=249736
Did you do continuity testing? You may have toasted the unit
. Just messing, but I'd still ask for a new one and go with the 4 wire setup, or was that 3?
Tested continuity, and its all fine.
Im out of ideas, so I think a new unit is appropriate.
