AMG65 - VR660
Old Aug 26, 2008 | 04:41 PM
V12Godspeed's Avatar
Your worst nightmare...
Originally Posted by Oxygen
Hmmm....
600 Injectors: $98.00
65 Injectors $106.00
600 Turbo: $2440.00
65 Turbo: $3040.00
The turbos are the same I think. It has been confirmed thru a few other threads.
Old Aug 26, 2008 | 04:49 PM
bfnnrgn's Avatar
SL65
The difference is probably the 65 ones have AMG stamped on them...hence the higher price.
Old Aug 26, 2008 | 04:50 PM
bfnnrgn's Avatar
SL65
By the way, I don't see the price in here. Is it the same as the 600 tune?
Old Aug 26, 2008 | 05:58 PM
Vadim @ FD's Avatar
S600TT, R350
65 tune is $2990.
All of our tunes come with 14 days money back gaurantee.
Old Sep 17, 2008 | 02:49 PM
onelightmind's Avatar
s65
http://www.snowperformance.net/
Vadim have you looked into any methanol water tunes to get more HP/TQ?
Could you set up a tune to adjust from 93 to 100 or higher automatically, like MB has theirs set up? Could this methyl water injection be included in aforementioned tune??
Maybe get to that 1K mark you are looking for on your SL.
Old Sep 17, 2008 | 03:52 PM
Thericker's Avatar
V12-Biturbo
Originally Posted by Vadim @ VRP
Here is our latest for 65s.
on this particular CL65, so it is only showing HP. Based upon speed aand HP, I am estimating TQ to be in mid600s accross the curve.
Vadim, why is the 65 AMG able to handle 650 rwto and be drivable, while you state the tuned 600tt can only handle about 590 rwto? is it possible during your testing fase your rear tires were too worn out?
Sean: I am limiting TQ down low in order to keep traction. Anything over 600RWHTQ and the rear tires go up in smoke
Also another member recently got Kleemann K2 on his SL600, on a Dynodynamics which usally read lower than Dynojets by at least 20rwhp it is a 93 octane tune while yours is 91 oct, & I know you stated more power could be had w/93+ on your tune...
Originally Posted by metalica_23
Well, the dyno is done. I'm pretty happy with the results. RWHP went from 453 to 503. RWTO went from 530 to 680! 680? Are you kidding me? Like I can apply any of that to the pavement initially. But, that certainly explains the get up and go I noticed when I'm hitting it at highway speeds.
The before/after Last time, it was 80 and the pulls were done quickly. This time, it was 90+ outside
He got 680 RWTO and reports no drivabilty problems, or losing control..
Let me try to go through these.
1.) Yeah, when the tech said "holy ****" after the pull, I knew it was something good. Of course, they mostly work on subaru's and light weight race cars, so they're not seeing a lot of torque typically. Having said that, they had a stock '07 SL65 a few weeks ago that pulled 481/650. So, I was pretty happy with my results beating the 65.
3.) No drivability issues whatsoever. If I floor it, yeah, it sits and spins. but, heck, it did that before I got the tune! I just have to feather the throttle a little bit more at takeoff now. At 60, I can still just punch it with no concern.
4.) I believe dynojet does typically give higher readings.
So why can the K2 ECU/TCU handle 680rwto & even a STOCK
handle 650 rwto & your S600
Sorry to be redundant I'm just very confused on these results, thank you for your time bud!
ps....Any chance you will be able to access/enable the throttle blipping/rev matching MHP is promising on their latest tunes?
Old Sep 17, 2008 | 04:09 PM
  #32
Vadim @ FD's Avatar
S600TT, R350
One answer - old tires and ESP off.
Old Sep 17, 2008 | 04:16 PM
  #33
Thericker's Avatar
V12-Biturbo
K.. so what are we going to be looking @ on my SL600 w/your 93+ ECU/TCU I really want to at least match a SL65 AMG RWTO 650+
and what about
Old Sep 17, 2008 | 04:56 PM
  #34
JAYCL600's Avatar
new balance
The car is completely driveable with immense TQ at the rear wheels, but that all depends on your definition of driveable. Even with 600 RWTQ and ESP off it will light the tires up. To keep the car sane keep ESP on. I have over 710RWTQ and its still under control. Especially for you Cali guys who have warmer weather and the tires stay warmer u should be fine.
Old Sep 17, 2008 | 05:27 PM
  #35
Thericker's Avatar
V12-Biturbo
That's what I'm talkin' bout Even stock the tires light up, I know the 600tt is capable of much more than 590rwto, & I'm on a quest to get it
Old Sep 17, 2008 | 06:02 PM
  #36
Oxygen's Avatar
W220 S65 AMG
I've spent some time researching the Brabus 6.3 Biturbo so maybe I can answer some of these questions...
Originally Posted by MB_Forever
I thought Brabus doesn't use the 6.0L TT from Mercedes They seem to have a 6.3L version of it, but I'm not sure if it's Mercedes or their own engine
Brabus uses the same engine as in the Mercedes 600 cars...
Mercedes:
Brabus:
Originally Posted by 2MANYCARS
Brabus stroked the 5.5L V12 MB engine to 6.3L along with bigger turbos, better cooling system, and wrapped all that in a custom tuned ECU to get that magical 730bhp.
I looked into the cooling mods that Brabus made to the Benz engine, but after a long search I found a picture that shows the Brabus engine using stock I/C's and stock routing of the coolant lines, stock airboxes...
BUT... compare the size of the turbine on the Brabus turbo above to this one on the stock SL65 AMG Engine (Picture courtesy of VRP Tuning)...
Do you happen to know why they used the Mercedes S600 engine and NOT the S65 AMG tuned engine?
Brabus was making the 6.3L Biturbo years before AMG Released the 65 series cars.
Old Sep 17, 2008 | 07:14 PM
  #37
Oxygen's Avatar
W220 S65 AMG
I forgot to mention, Brabus does offer tunning for the 65 series with the 6.0L V12TT Engine:
BRABUS T65 S
Basis: S 65 (W221)
Power enhancement by modified engine electronics with modified boost pressure regulation and syncronized ignition- and injection-engine maps. Additionally a back pressure lowering metal-catalytic converter is used. Furthermore a special exhaust gas turbocharger is built in with a more effective intercooler.
Technical data:
Displacement: 6233cc
Bore/stroke mm: 83 / 96
Compression ratio: 9.0 : 1
Torque Nm: 1320 Nm @ 2100RPM (limited at 1100 Nm electronically)
Power output kW/PS: 526 / 715 @ 5100RPM
Old Sep 17, 2008 | 07:57 PM
  #38
Vic55's Avatar
Administrator
Actually the 65 turbos are bigger and the intercooler is the same- please correct me if I am wrong, but if you do you will be banned
Old Sep 17, 2008 | 08:50 PM
  #39
Thericker's Avatar
V12-Biturbo
You're wrong lol.....
Old Sep 17, 2008 | 09:06 PM
  #40
Oxygen's Avatar
W220 S65 AMG
You're wrong.
Turbos are the same size and so are the intercoolers, the 65 Heat Exchanger is twice as tall and twice as think as on the 600 cars.
Old Oct 1, 2008 | 01:19 PM
  #41
bfnnrgn's Avatar
SL65
Has anyone ever stepped up to the plate and got this tune done? Any customer dynos or timeslips?
Old Oct 1, 2008 | 02:59 PM
  #42
Marcus Frost's Avatar
Real Cars
A little birdie told me that there's a 65 running around the midwest who's had good results with this tune, but I am unforutnately not in a position to post any results. It seems like the winning ticket for the 65s is cooling and tune. Tunes generate substantial power but are limited because of cooling, the combination of both has yielded impressive figures.
-m
Old Oct 1, 2008 | 03:40 PM
  #43
-m
Thats not nice....., We need to know who this is!! Why not just inform the remaining humble 65 owners. I don't see myself paying for anything over 3500 beans right now. We need to investigate who this is...eventhough I may have a clue. vadim is always mentioning him....
Old Oct 1, 2008 | 06:49 PM
  #44
NA1's Avatar
NA1
W211 E55 AMG, LS2 GTO
Decent result
Old Oct 2, 2008 | 10:29 PM
  #45
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Vadim:
Any news on the airboxes?
Thanks,
Tom
