Track advice
12.5's are not bad for your first time at the track, especially considering you only got to make 2-3 passes. That is not enough time to lear your car and how to launch/drive it. Hell, i have made probably 30 passes in my car and I'm still learning it. You saw some of those guys last night with blowers and slicks on their cars struggling to make 12.5 passes. Your 12.5 pass was probably in the top 20 percetile of the cars running in our class last night and it was by far the largest class/group. Most of those cars were running high 12's.
I'm sure my car is totaly different than your but I turn my T/C off on all my runs. T/C cuts too much power off on my car, but I would wait for some answers from some other E 55 and E63 guys, I don't want to speak for them since I have no clue about your cars.
Are you heading out to the L.E.T event at US 41 on Saturday? You should think about it, there are only going to be 20-25 guys goign and you can make as many passes as you want. Contact ChicagoX or AMG Jerry for mor info. I also think there is a thread in this section.
Good Luck
-Get good rear tires (PS2's in 275mm width worked well for me)
-Do a burnout to warm them up a bit.
-I left traction control on, tried to modulate throttle as if it was off though.
-Do not brake-torque, just roll on the throttle.
That got me a 12.1XX E/T in my second EVER 1/4 mile run. (not second trip to the track, second run) After you get good and used to it and build some confidence in what you are doing, try it with TC off. I never got that comfortable with my E55, but now I am used to the dynamics of it all, so I never use TC anymore in my M6.
That's what I did...
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
The drag race sticky has some good advice: https://mbworld.org/forums/w211-amg/236339-drag-racing-how.html
Rolling into the throttle seems to help the most, taking about one second to reach full throttle. Pre-loading the transmission seems to cause the ECU to cut power and makes the car launch slower.
Good luck on your next runs!
) Do a burnout in the water box (controversial but it works for me.) Make sure that you have at LEAST 1/8th a tank of gas. I prefer just over 1/4 tank.Set the suspension to C and the transmission to S.
Find the groove at the tree. If it is prepped well, you can hear the sound of the tires and VHT sticking to one another as you roll up.
Forget the green light. You are just trying to get your launch right. If you are too focused on getting out of the hole, you will screw up your launch.
when you are ready to leave, roll hard into the throttle but only after you are fully off the brake pedal. Don't slam it. Get it to the floor within 1.5 seconds of releasing the brake. Hang on.
I agree so much with chiromikey. Here is the only thing I did different. First, I ran drag radials (BFGs) so i definitely did burnouts. How you do one has EVERYTHING to do with your 60 times. I run my car in dyno mode, so no traction control. I get in the water, hold the brake and slowly add gas as I modulate the brake. I try to get the tires to slowly pull and go into a spinning burnout. If you just spin them out, you may not get enough energy into them. If you are running Z rated tires, then it is likely best to do a small burn anyway, since they have a wider temp range. Anyhow, once the tires are spinning nicely, I slowly modulate the brake to let the car walk out of the water (keep the wheels smoking) and into the swept area. Then, just like at the start of burning, I try to slowly bring the wheels to a halt. This again helps to apply more heat but more importantly it gets that layer of melted goo off.
On a nicely prepped track, you can almost just mash and go. the car feels AMAZING when that happens. If the track is dirty, then you will have to rein in those 500 horses.
