Update: MHP ECU/TCU Tuning (Throttle Blipping, etc, DONE!)
Please don't jump on my case, I'm not an expert at any of this performance or racing stuff, nor am I trying to act like one, I'm just speaking from what I have experienced with my car(s) at the track.
BTW, does anyone know what Andy's car weighs in at vs. my CLK 63 cabrio? is a 12.92 even a decent time or should I be ashamed of it? I actually thought I would have been able to lay down some 12.50's.
If you say they're archaic, that means you must be doing something better, right? Please elucidate on their method vs. yours, if you will.
Or are you not really able to look at their tunes at all....which is what I suspect.
As far as archaic you either flash through the obdII port or you de-solder the chip which gives you access to all map data.
Placate me, what's the most power/torque you've ever seen from a 65 with Powerchips or anyone else's tuning?
I have seen just about all of the "tuners" performance(I use this term very loosely) software because it is my software engineer that reads these files and points out their lacking parameters.
Archaic meaning that they don't have the ability to delve deep enough into the code itself instead of just changing some figures in the respective tables.
Do you know about any of what you are asking or are you just like the rest of the select few naysayers that question EVERYTHING(relevant or not) and don't know or understand what you are questioning even if it was explained to you?
Andy-
I hope you don't even acknowledge the quoted post. I think I have it covered.
Again, please answer this, what's the highest HP/TQ 65 you've seen to date on pump gas? Or race gas?
Horsepower: 582.24 HP
Torque: 754.42 ft-lbs
all at the wheels and on pump.
With the results you guys got in the C63, you should be able to push well over that with tune/tcu only. Can't wait to see the results.
If I'm not mistaken SGC has made over 610 rwhp on his cl65 with just an ecu/tcu.
Wait until you see the 65 numbers! It will blow your mind and every thought you've had about the software tuning of the 65 series engine!
Are you guys kidding me? Your charging that much for 1100 Rwtq ? Its waaaayyy too much I think your just trying to Gouge us AMG owners - who exactly do you think you are?
I have this friend thats a wiz at computers and stuff - he's even scored over a million on brickbreaker and u should see him on Halo 3 - anyways he's personally gotten over 1500 RWTQ accessing the code from his friggin PSP.
And thats on the 6 cylinder 350 motor. SO like get back to the drawing board dude.
