X Pipe for 63 engines
Old Sep 21, 2008 | 08:52 PM
drop997stop's Avatar
08 E 6point3-sold- 11 caddy cts-v-sold, 2012 E63 Palladium Silver
I know some guys on the boards have a bought a X pipe on ebay and said it is great for the money.
My question is what size inlet and outlet do we use. A guy has a 3 inch inlet and outlet on ebay. IS this the correct size for our pipes on a 63.
Also, I have already removed my resonator. Do I add the x pipe in addition to the resonator delete or would that hinder the performance if I run both,
http://cgi.ebay.com/ebaymotors/3-inc...spagenameZWDVW
thanks guys
Old Sep 21, 2008 | 09:37 PM
Fr33kn63's Avatar
E63 AMG
thanks guys
on our cars as I found the pipes are 2.75" so finding something in the size can be challenging. I swapped out 75% of my exhaust to a 3" system to avoid this issue. You might be able to find someone to slightly stretch your pipes to fit the 3" connection for the lessor expensive x-pipe and TIG weld it together. It should be fine that way. If you find an Xpipe in the 2.75" size you will pay through the nose for it IMObservation
heres what i did....
http://gallery.me.com/jfmillr72#100312
Old Sep 21, 2008 | 11:39 PM
bobgodd's Avatar
2004 E55
Most exhaust shops can take a 2.5 or a 3" x-pipe and make it fit without a problem.
Old Sep 22, 2008 | 12:48 AM
alphanumeric's Avatar
is the e63 and e55 the same diameter exhaust pipe?
Old Sep 22, 2008 | 03:20 AM
Did you remove a set of cats on your system, did you noitce any difference going to the 3 inch piping
any sound clips, really intersted in what it sounds like
Old Sep 22, 2008 | 08:51 AM
Fr33kn63's Avatar
E63 AMG
In my opinion I beleive going with the 3" is a better choice. If your exhaust is currently 2.75" and you got a 2.5" setup you are in theory choking your exhaust and actually restricting your exhauss ability to breath. Thats why I opted to go larger and yes i did delete my secondary cats at you can see in the gallery pics I posted before.
Heres a sound clip of what it sounds like...
http://www.vimeo.com/1746831
I also did see some power gains. Here is my Dyno Sheet.
The low number is my car stock with JUST the Renntech ECU tune and no charcoal filters vs. higher number is Renntech ECU tune and VRP CF boxes with highflow filters, and exhaust work 3" pipes, x-pipe and no secondary cats.
Old Sep 22, 2008 | 10:03 AM
bobgodd's Avatar
2004 E55
https://mbworld.org/forums/showthrea...235&highlight=
Old Sep 23, 2008 | 03:47 AM
NSX2NV's Avatar
03' E55 Techtite Grey
If I KEEP the primary cats and replace the Y-Pipe with X-pipe and do 3" all the way back with secondary cat DELETE will I get a check engine light?
Old Oct 26, 2008 | 05:38 PM
lexaltezza's Avatar
08 CLS63
Did you notice any loss in low end torque with this setup? Is there any drone?
Old Oct 26, 2008 | 07:04 PM
jangy's Avatar
2015 S212
no, but make sure you cut after the sensor.
Old Oct 26, 2008 | 07:13 PM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
Excellent info and numbers!!!!
-Aaron
Old Oct 26, 2008 | 07:34 PM
Fr33kn63's Avatar
E63 AMG
thx. Yeah I am going to same place on Tuesday for more dyno pulls with the new MHP tune. Hoping to improve on these numbers.
