My '03 E55 baseline dyno pull...
Old Sep 23, 2008 | 03:15 AM
NSX2NV's Avatar
03' E55 Techtite Grey
Do the new VRP Pulley and ECU Software and dyno again
Old Sep 23, 2008 | 11:35 AM
The Godfather's Avatar
4 wheeled car.
So that would put me at what at the wheels? 450?
Old Sep 23, 2008 | 12:20 PM
Vadim @ FD's Avatar
S600TT, R350
VR550 will put you at 460-470RWHP.
Old Sep 23, 2008 | 01:41 PM
4 wheeled car.
alright well first and foremost I need cooling mods. will the cooling mods help maintain whp throughout dyno pulls and will prevent it from dropping like it did?
Old Sep 23, 2008 | 02:31 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Was Your car in DYNO mode on the 3rd gear run?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Sep 23, 2008 | 02:46 PM
Vadim @ FD's Avatar
S600TT, R350
Cooling mods will help more on the car with more boost. Stock car makes only 10 lbs. of boost in 3rd gear and stock cooling system can handle it fairly well.
The graph falls of because of cam timing and exhaust restriction.
Old Sep 23, 2008 | 02:52 PM
  #32
4 wheeled car.
yes I was in dyno mode.
Old Sep 23, 2008 | 06:04 PM
  #33
EdoubleNickel's Avatar
SOLD 04 E55 Now 93 w124 3.2 sold W210 E55 sold waiting on W211 E63 p030
Skrew the dyno sheet.. those rims are Hawt!!!
Old Sep 23, 2008 | 08:37 PM
  #34
cls55's Avatar
VADIM,what is a tcu program?
Old Sep 23, 2008 | 09:04 PM
  #35
what rims are those.
Old Sep 23, 2008 | 09:09 PM
  #36
4 wheeled car.
These are Japanese wheels: Work VS-XX in 19's
Old Sep 23, 2008 | 10:32 PM
  #37
I Like Soup's Avatar
2003 E55 AMG
Good info here.
I'd seriously consider doing cooling mods as well. They aren't that expensive and I like to think they umm...extend the life of my engine or something due to less heat stress.
