275 or 285 rear tire?
07 E63 P30,08 997 911 TT 700EVT,07 Audi Q7 S-line 4.2
Anyone had rubbing with 285/30/19 rear on E63? I am using HRE Comp's.
thanks for the info.
1 Post
AMG E55, Stage 1, Strait Pipe from Primary Cats
I run Kinesis K29's 19x10 285/30/19 rears and no rubbing at all, and I am dropped low. You should have zero rubbing and if you do, your offsets are wrong.
wheels
285 on your comps will be perfect, dont go any bigger though, 275 will be stretched alittle. If your wheels were built for a e class as your wheels were then 285 is the perfect size
2017 S63 Coupe Iridium Silver
That combination will give you a larger diameter in front (26" ) and smaller at rear (25.5"). 255/40/18 look like baloons on E-class.Attached photo of SL55 wheels with 255/40/18 and 285/35/18.
For 18" wheels I like 245/40/18 F and 275/35/18 R.
In 19" I go bigger, 255/35/19 and 285/30/19.
2015 S212
I prefer 265/35 fronts and 295/30 rears
