***Code Three Performance Spearco HEAT EXCHANGERS for Sale!!!!***
Old 10-28-2008, 08:04 PM
phatmitzu's Avatar
2005 E55
Originally Posted by TopGun32
that's my car!!!
I was the beta test on that unit...
by the way.. if you already have a CP3 unit, the swap to the new HE was very simple.
Just remove the plastic air underbody.. and you have enough room just to unbolt the older unit and bring up the new one.
less than 30mins and very little coolant loss.
This only applies cars with CP3 units already installed.
I have done plenty of data logging this supper...
its basically 10-15 degrees over ambient when cruising at 70 on a 100 degree dat.
It reaches 140 at around 110mph.
but the difference is recovery time is key.
Hey,
You went with the new core? I still have the old core...
Old 10-28-2008, 08:09 PM
TopGun32's Avatar
Originally Posted by phatmitzu
Hey,
3 months ago..... and tested during all peak summer days.
Old 10-28-2008, 08:20 PM
Code3 Performance's Avatar
C32, Cobra, 700hp Vespa
that's my car!!!
Joe,
Thank you so much for the post and for your help with testing this product! Also, your images have helped A LOT!
On a side note, the actual production unit is 4+ inches longer than the beta unit. We decided we had a little more room and would extend it a tad.
-Aaron
Old 10-29-2008, 02:10 AM
If anyone has questions please feel free to email me
Sincerely,
Aaron
Old 10-29-2008, 09:42 AM
C32madness's Avatar
2006 E55
I am interested but still waiting for the pictures of the finished unit uninstalled. Experanced the SC shutdown on my run to 140 last night. It was 55ish outside and I am still stock.
Old 10-29-2008, 10:10 AM
prodigymb's Avatar
997TT, R8 V10+, G550, Plaid S
Aaron,
Did the heat exchangers ship out?
Mark
Old 10-29-2008, 10:12 AM
  #32
AMG Rider's Avatar
2004 MB E55 AMG, 2006 Audi A6 4.2, 2008 WRX STI
Originally Posted by MJ50
i'll be ordering mine soon...
Hite fanatics here~lol
I can't wait till i pound some of those in Korea...lol
Old 10-29-2008, 12:42 PM
  #33
psk145's Avatar
2006 E55
damn this economy.....if things werent so slow, I would be throwing my credit card at code 3.
Old 10-29-2008, 01:41 PM
  #34
phatmitzu's Avatar
2005 E55
Werd.
Old 10-29-2008, 01:44 PM
  #35
Lol!~ Don't worry, we completely understand.
Old 10-29-2008, 02:43 PM
  #36
jikjak's Avatar
CLS55 AMG & RRS S/C
would this work on a cls 55?
also does it come with all the necessary parts for the install?
Old 10-29-2008, 05:49 PM
  #37
TopGun32's Avatar
Originally Posted by Code3 Performance
Joe,
-Aaron
No problem Aaron/Brandon.
Next up!
ECU and separated IC HE circuit from the engine coolant.. maybe with a small reservoir. like the C32 unit.
Space is limited, but I'm sure we can find a way.
Old 10-29-2008, 06:58 PM
  #38
Super Moderator
BenzoBoi's Avatar
W221
I'll let Aaron chime in on fitment, but the only thing you get/need from Code 3 is the upgraded H/E. You use yer stock hoses and clamps...it bolts right up just like stock, but bigger!
Old 10-29-2008, 08:23 PM
  #39
jikjak's Avatar
CLS55 AMG & RRS S/C
oh i see so it replaces the stock heat exchanger?
i just assumed it was an add on
Old 10-29-2008, 09:11 PM
  #40
Super Moderator
BenzoBoi's Avatar
W221
You got it...you take off the stock H/E and replace directly with the Code 3 one...
Old 10-29-2008, 09:26 PM
  #41
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
Do you have any pictures of the final product with brackets welded on? What are the overal dimensions?
Old 10-29-2008, 09:27 PM
  #42
jikjak's Avatar
CLS55 AMG & RRS S/C
nice! i hope it fits the cls as well then hehe
btw is it better to do this or to get one of those IC upgrade kits from VRP?
which setup will give u more cooling?
Old 10-30-2008, 01:41 AM
  #43
jpmt's Avatar
W211 E55; W164 ML63
Does the coolant system need to be either flushed or bled after install?
Old 10-30-2008, 09:23 PM
  #44
We'll get the dimensions to you shortly and shoot you some pix. The ones I have at-hand are fairly bad. Lol.
Sincerely,
Aaron
Old 10-30-2008, 09:26 PM
  #45
Thank you for the post! We're fitting one in a CLS shortly, just debating on whether to bring a car in or find a local CLS. I'm waiting to hear back from a friend of mine, which I hope is very soon.
Regarding our kit versus VRP's, both are excellent products, it just comes down to personal preference.
I just spoke with Brandon and you do need to bleed the system when any coolant mod is installed.
Regards,
Aaron
Old 10-30-2008, 10:42 PM
  #46
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Whenever the heat exchanger/intercooler fluid circuit has been breached, e.g., installing a heat exchanger or its pump, it’s imperative to ensure the system is subsequently bled of any residual air in order to maximize the effectiveness of the modification(s):
photo credit BrianS
Old 10-30-2008, 11:57 PM
  #47
photo credit BrianS
Absolutely correct! I just checked with Brandon and he confirmed such.
-AS
Old 11-16-2008, 06:06 PM
  #48
PLATINUM SPONSOR
2003 CL55
How much coolant does the stock E55 H/E hold verses the new Code 3?
Old 11-17-2008, 04:25 PM
  #49
TopGun32's Avatar
the OEM holds 28oz
The old Code3 Unit i used to have was able to hold 80oz
The new Spearco unit is slightly better, more efficient.. more rows and better entry points.
Probably holds 60+oz.
Old 11-17-2008, 07:11 PM
  #50
prodigymb's Avatar
when are these shipping?
Quick Reply: ***Code Three Performance Spearco HEAT EXCHANGERS for Sale!!!!***
