P265/40R18 Mickey Thompsons - will these rub?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I have the following tires mounted on 18 inch Kosei's
P265/40R18 diameter: 26.5
and it looks like the diameter is a full inch taller than my current 275-30-ZR19s. I wonder if it will rub?
Sucks the rolling diameter has increased since it's like having taller gears...not good for drag racing.
Not sure if you will rub, but your car is very low.. I doubt the taller tires will help you in the 1/4, the e55 has long gears as it is. if anything i would drop down in diameter. have you considered the bfg drag radials?
G63, 360CS, CLK63 BS, 997.2TT, 328D
Yeah i almost got that size in this tire but opted to go with the 245-40-18s since they are almost the same as stock and wont gear up the car as much as the 265s.
Justin
Justin
'10 Porsche Turbo PDK, 500e, GL450
taller tire for drag racing
I was also looking into use the 265/40 18 MTs ... but its even larger difference for me.
I can always raise the car for drag racing with the coilovers ...
Can someone explain the negative effects of taller tire while drag racing? If it reduces the amount of torque initially I'd say thats a benefit to me. I can't hook with the 245.
E63 P30, CL500 Sport
No, these tires will NOT rub...... My friend put these tires on his stock E55 rims a couple of months back and he said they were a perfect fit on the car plus they hooked very well at the track. However, it apparently "messed" with the ECU a little and he's currently investigating the situation a little more....
Justin
