Black Series 1/4 time
Old Nov 3, 2008 | 03:20 PM
LZH's Avatar
LZH
CLK 63 Black Series, 2009 S550, 2011 Range Rover Supercharged, BMW F800 GS Anniv Edition
My background is in road racing and I've never been much of a drag racer. But, with that being said and with all the talk of 1/4 mile times around here recently; I thought I'd see what my car would run. So, I went out to California Dragway yesterday. Here are the results:
Actual - 12.766 @ 111.67 mph.
Corrected - 12.445 @ 114.624mph.
My car is bone stock less the charcoal filters. Tires are MPS on the stock wheels. I ran against my buddies E63 that is pretty modified. He has Renntech tune and some exhaust work (Eismann mufflers and X pipe, no resonators) and runs 20" HRE's. I was in the left lane, he was in the right. My reaction time is horrible - I was having a hard time getting the car staged as it was a pretty frantic environment with lots of people rushing to make passes and the guys running the tree were not very helpful. Anyway, enough with my excuses Here's the timeslip:
File Type: pdf
Old Nov 3, 2008 | 03:32 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
My car is bone stock less the charcoal filters. Tires are MPS on the stock wheels. I ran against my buddies E63 that is pretty modified. He has Renntech tune and some exhaust work (Eismann mufflers and X pipe, no resonators) and runs 20" HRE's. I was in the left lane, he was in the right. My reaction time is horrible - I was having a hard time getting the car staged as it was a pretty frantic environment with lots of people rusing to make passes and the guys running the tree were not very helpful. Anyway, enough with my excuses Here's the timeslip:
It takes talent and lots of practice to get the launch right in a Black Series. It took me a good 8-10 passes before I even got my 60' below a 2.0 I can tell you that consistant 1.80's and even high1.70's on the stock tires are very easily attainable with a 2000 rpm brake torque launch and 22 psi in the rear Corsas. 22 psi is the magic number. Leave on the last yellow and then qucikly roll on the throttle, don't mash it or you will spin the tires for half the track. Were you in M or S? You should be running it in S auto, manual shiffting costs you about 3/10ths in this car, you can't beat the auto upshifts.
Old Nov 3, 2008 | 03:35 PM
Vic55's Avatar
Administrator
You should have stopped by where we were. We were all calling you over and you said you were coming back?
Oh btw the E55's all ran in the 116's and 117's including a 12.1xx and 12.0xx (uncorrected). Of course they are modded but traction was an issue.
Old Nov 3, 2008 | 03:40 PM
LZH's Avatar
LZH
Thanks Jim - Yeah, that was my 4th pass of the day....the previous passes were spent just figuring out how to launch it. I did what you mentioned and stall braked the car then just rolled into the throttle in first gear. All passes were done in S mode with the traction control off of course. I didn't really want to mess with my tire pressures so I left them alone. I was running 36psi on the rears, cold.
Like I said, with all the heated debates of late about 1/4 mile times....I felt this was something I needed to do so I could get a god baseline on my car before making any changes/mods. I've got access to a good dyno shop, so I think that is going to be the next step - beseline 1/4 mile run as well as stock dyno. Then I plan on having MHP tune a spare ECU for me so I have no downtime on my car. After pulling the stock ECU, I'll throw the MHP ECU in the car and then run 1/4 mile again as well as dyno so I can get the most accurate possible before and after numbers.
Thanks again for the tips
Old Nov 3, 2008 | 03:43 PM
LZH's Avatar
LZH
***** sorry Vic !!! I had no idea you were there man !!! I just saw that silver E55 (which sounded AMAZING) and AMGSC's car. Had I know it was you I would have some over and spent more time....I had some phone calls to make between passes - wife was yelling at me for bailing on her !!!!! Anyway, my bad dude - next time...I prefer Mexico runs anyway
Old Nov 3, 2008 | 03:47 PM
jrcart's Avatar
Well, they claim that for every 1/10th you save on your 60' it translates to 2-2.5/10ths or so at the other end. So if you could get that 60' down to a 1.8 using that formula your e/t would be in the 12.10 range which is par for the course for a stock Black Series.
Old Nov 3, 2008 | 03:56 PM
BenzoBoi's Avatar
Super Moderator
W221
It was nice seeyin ya roll by at the track yesterday. You should have joined our lil benzo group and hang! Next time...
Old Nov 3, 2008 | 04:06 PM
JamE55's Avatar
Out Of Control!
Maybe i'm missing something here. You were on the left and your Renntech'ed modified E63 buddy on the right?
Your stock CLK BS times:
1/4mi - 12.76 @ 111mph
Renntech E63 times:
1/4mi - 12.98 @ 108mph
Your stock CLK BS ran faster than a Renntech modified E63? What am i missing or was this another car you ran and not your buddy?
Old Nov 3, 2008 | 04:57 PM
MHP's Avatar
MHP
'09 C63 AMG
Luke,
Great job for your first time in the car! The launch is 90% of a drag race, once you get that figured out you're ETs will drop accordingly. Then again, you're going to have to relearn the launch post tune.
Old Nov 3, 2008 | 05:10 PM
DFW01E55's Avatar
'14 ML BT
My background is in road racing and I've never been much of a drag racer. But, with that being said and with all the talk of 1/4 mile times around here recently; I thought I'd see what my car would run. So, I went out to California Dragway yesterday. ...
BIG mistake.
Now you'll be hooked on a dual purpose car like jrcart.
When your bill from MHP or VRP or Evosport just says "card on file", you'll know you need help.
You must have had some spin off the line ... get the launch down and you'll be searching for the next .1 second off.
Old Nov 3, 2008 | 05:28 PM
vegastrashed's Avatar
2007 E63 AMG
This Sunday. Let me know...
Old Nov 3, 2008 | 05:31 PM
2007 E63 AMG
I have a suspicion that the E63's exhaust setup is robbing him of power.
Vic55's Avatar
Administrator
Its all good, I kept looking back wondering where you went
And yes, Id much rather do the Mexico runs- next time you'll have to join in- we need a BS to rep
Old Nov 3, 2008 | 05:39 PM
Vic55's Avatar
Administrator
Renntech E63 times:
Without knowing the mods, it would be hard to speculate. Could be a simple but old ECU mod which doesnt yield too much or it could be other items. Either way IMO the stock BS is faster than a stock 63. So minor mods to the 63 still could be allow the BS to trap 3 mph better.
Old Nov 3, 2008 | 06:24 PM
JamE55's Avatar
Out Of Control!
Agree but still kind of weird considering stock vs modified.
Old Nov 3, 2008 | 06:55 PM
LZH's Avatar
LZH
I don't think it's odd at all. Consider that the Black Series weighs less and the E63 is running 20" wheels which don't help trap speeds. Those two factors make up for the tuning IMO which puts the car almost as fast as mine. After tuning to my car the results will be much more pronounced.
Old Nov 3, 2008 | 07:02 PM
jrcart's Avatar
What kind of "tuning" are we talking about?
Old Nov 3, 2008 | 07:08 PM
LZH's Avatar
LZH
Not much really...The car is already plenty fast for the street IMO - especially where I live. Just a good tune and some exhaust work is all I really want to do. I thought about going crazy, but I'd much rather spend the $$$ making my boat faster
Old Nov 3, 2008 | 07:14 PM
Hammer Down's Avatar
2015 E63S, 2018 E63S
hmmmm so if I get my 1.97 and 2.0 60' down to 1.8, instead of my 12.2 my time could be would be????????
Old Nov 3, 2008 | 07:17 PM
JamE55's Avatar
Out Of Control!
Makes sense. Per Edmunds site the BS weighs 3,948lbs and the E63 at 4,035lbs. Delta of almost 100lbs.
Old Nov 3, 2008 | 09:19 PM
MHP's Avatar
MHP
'09 C63 AMG
20" wheels will (aside from likely being heavier) also reduce overall tq multiplication which hurts acceleration especially from a dig.
Old Nov 3, 2008 | 09:58 PM
LZH's Avatar
LZH
Totally, but the E63 had me off the line every time. Granted his R/T's were better than mine....but he seemed to be able to put the power down better than me....He (the E63 driver) had a camera mounted in the car and took a video of this race. You can clearly see him jump out in front and then me pass him down the last 3/4 of the track. I'm waiting for him to post it on YouTube and then I'll post it here. No doubt in my mind that my car would continue walking away from him up to high triple digit speeds....
Old Nov 3, 2008 | 11:11 PM
MHP's Avatar
MHP
'09 C63 AMG
Good deal. What color is your BS Luke?
Old Nov 3, 2008 | 11:49 PM
Max.H's Avatar
E55
nice numbers luke!
Old Nov 3, 2008 | 11:50 PM
LZH's Avatar
LZH
Silver - had a hard time deciding b/w that and white.
