Paging: Real I/C system seperators.
The car runs hotter than desired, among other reasons, due to emissions requirements. A t-stat should be viewed as an additional rather than substitutive mod.
Separating the systems does provide the absolute lowest IATs, according to the hard data out there.
With the ECU being so sensitive to temp changes, both coolant and IAT, I think that the best way to go for performance is to do both.
1) Lowering the fan engagement speed and upgrading the T-stat help with controlling the coolant temps.
2) Adding the larger HE, upgraded pump, and separating the systems will help with IATs.
With these cars pulling THREE stages of timing for both IAT and coolant, wouldn't both be logical?
I drove the hell out of a new 09 ZR1 today and then studied the coolant I/C system... That car has 3 H/E and also shares the same expansion tank at 638hp.. What does that mean? Probally nothing but was interseting to study.. I expected to see a seperate surge tank, but no it is shared..
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
now if you want to compare the zr1, if we had 3 h/e's and a more efficient i/c i highly doubt any of us would be studying iat's as much as we have over the past few years and i doubt we would care if the sytems were tied together.
