What Type of Wheels Are on this E55??
Old 11-19-2008, 03:17 PM
AMGTestDriverNJ's Avatar
86 190E 2.3-16v, 92 500E, 03 CL55 AMG, 08 E3504M Brabus
Originally Posted by li-m5
here are the 20's in silver on my car !!
http://s426.photobucket.com/albums/pp350/LI-M5/
Same design but different wheel maker. I actually have these wheels too on my C class in 19" in a gunmetal finish.
Check out post #22 you can see what the wheels that are being discussed look like in silver w/o a lip.
https://mbworld.org/forums/e-class-w...aser-pics.html
Originally Posted by Busta Riles
I've been looking for wheels for my E55, and really love these ones, but am also worried about bending. If i buy a forged wheel, are they less susceptible to bending?
Most likely, but as a rule of thumb, no matter how good a wheel looks, you get what you pay for. Keep that in mind.
Old 11-19-2008, 04:02 PM
E55 Bulldog's Avatar
2012 C63 Black Series, 2003 Hummer H1 KSC2, 2003 Hummer H1 HMCO, 1997 Hummer H1 HMC4, 1969 Jaguar E
Nice!!! Very Nice... it is good to see them in 20'' too.
Old 11-19-2008, 04:48 PM
jdeastbay's Avatar
2005 E55 / 2008 E63
Yes, I went with 19's. 8.5 front and 9.5 rear with 245/35-19 and 275/30-19 tires. If I'm not mistaken, these are the same specs for the 19" OEM option including tire size. So I'm assuming they will fit the gap similar to those. As a note, the wheels I ordered have the anthracite interior and polished face.
And I'm a big believer in you get what you pay for, hence my plan to keep the original wheels as fall back. I should have them on by mid day Fri and should be able to post by the afternoon.
Old 11-19-2008, 05:58 PM
NXtremeJeep's Avatar
GT-R
Most wheels, especially multipiece, bend if they are exposed to the dangerous conditions that cause wheels to bend (i.e. potholes, dips, bumps).
Old 11-19-2008, 06:12 PM
li-m5's Avatar
2007 p30 e63
i've had these reps on the car for 3mo's and have exposed them to all sorts of nyc ****tty roads and all seems fine so far !!
knocking on wood as i type
Old 11-19-2008, 10:21 PM
  #32
PLATINUM SPONSOR
Exotic-metal55's Avatar
2003 CL55
What was the rim weight each? Do you drop some un-sprung weight over stock?
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old 11-19-2008, 11:40 PM
  #33
Busta Riles's Avatar
1969 280S, 1991 300E
You have a CL55 with replicas on it....are you happy with them?
I've had replicas on my CLK320 & E320, but am hesitant to put them on my E55 because of the amount of power this car has.
What are the advantages to spending the $5k for nicer wheels over getting reps for $2k?
Old 11-20-2008, 12:02 AM
  #34
GT-R
Not sure which wheels you are talking about, but my 19's are about 2lbs lighter on all four corners than the stock 18's.
Old 11-22-2008, 05:15 AM
  #35
NSX2NV's Avatar
03' E55 Techtite Grey
Originally Posted by daniel3ooo
They look good...
Missing taillight...
Old 11-22-2008, 08:55 AM
  #36
vizionclk430's Avatar
2002 clk430
That pic was taking in front of Sonic MS I believe they were either swapping out tails or tinting the old ones.
Quick Reply: What Type of Wheels Are on this E55??
