*** ECU DUMP UPDATE ***
Automotive Connoisseur Group Inc of San Diego ( ACGSD )
Your Southern California Autobroker
877-4-ACG-SD Now (877-422-4736)
He came to my place of work about 6pm (major traffic time here in S.D) with all his fancy Tuning tools and computer stuff
Well, he put it all back together, installed it in my car and The Beast started right up and it has been fine ever since. We are not sure what happened to the ECU but whatever James did seems to have done the trick
Again a BIG THANKS to James from ACGSD for his help. The best part is he did all this on his own without invoce or $$
NOW that's some great PR work
I now have two brand new ECU's and will be coding them on Monday morning and getting one tuned and leaving the other one stock.. Also a BIG THANKS to Andy from MHP for getting me an ECU so fast. These two Tuners have all the CLASS we can ask for here on the forun, They both stepped up
Thanks James great job.. and Andy for lightning fast ordering, If his tune is as FAST as his customer service it should be BADD AZZ
I am going to have Andy try to reflash my broken ECU then and see if she comes back to life as well.
Then I will have 3 ECU's total. One Kleemann, one VRP and one MHP. Gonna need a bookshelf or something soon.
I have two I am coding on Monday morning. Man I thought I was the only
one around here. I have Bookselfs on1/2 off TODAY ONLY...
I like the idea of having an extra ECU, how much is it?
How does this work? Let's say I drop tuner X ECU in my car, then 2 months later, switch to tuner Z, then back again. Tuned ECUs seem to perform better after 200 miles or so, if you pull one out will it retain it's adaptations, or do you get to start fresh again?
Just curious, as it seems that aside from the expense, you could have several "perfected" tunes for different occasions, octanes or even mods (not that you pull mods on & off frequently). What's the scoop?
You are correct about having spot on tunes for different occassions (pump gas v race gas, etc.) there are no limitations as far as that is concerned other than the amount of $ you want to spend on spares.
They all need to learn regardless of tuner or even what the tuner says. Confusing topic because even some tuners will say they are 100% right away but the customers completely disagree.
I know rarfinancial has had the same experience with his tunes.
Anyone but Rick and I would be calling BS all over but I do think that James has been great to Rick.
If a gasket is thick enough to drop static C/R into the 9s I wouldn't touch it with a ten foot pole.
A phenolic (wooden) spacer used as a head gasket would make for a novel concept.
I'm not a nitrous guy myself, but you cannot deny it's effectiveness especially when used on a solid N/A platform. These motors take naturally to nitrous and when properly tuned will make incredible power and TQ.
Spraying and boosting a 11.3:1 motor on CA 91 would be like strapping yourself down and flipping the switch.
I'm gonna try my hardest to make it
